GD&T Fixed Fastener Condition Tolerance Calculator
Geometric Dimensioning & Tolerancing Training
This calculator calculates fixed fastener position tolerances utilizing principles and concepts withinASME Y14.5-2009 and ASME Y14.5M - 1994, Geometric Dimensioning and Tolerancing (GD&T).
Open Fixed Fastener Condition Calculator
Negative Tolerance numbers indicate interference.
This calculator will calculate the unknown for the given conditions. Four (4) inputs are required,See the application illustration at bottom of page.
Fastener (Shaft) Diameter - This is the maximum size (MMC) of the bolt, shaft or other feature of size.
Hole Diameter - This is the smallest hole (MMC) for the given feature of size.
Fastener (Shaft) Tolerance - The positional tolerance of the installed bolt, screw or shaft. (Calculator does not compensate for projection zone).
Hole Tolerance - This is the clearance hole positional tolerance.
Clearance (C) - This is the clearance desired for the hole - fastener (shaft) when the holes are produced at a worst case positional tolerance. This value is set to zero (0) for a line to line fit.
Related Resources:
- True Position GD&T Tolerance Calculator
- Tolerance Calculator Floating Fastener Condition
- Tolerance Calculator Projected Tolerance Zone
- Tolerance Calculator 2 Mating Features @ MMC
- Tolerance Calculator 3 Mating Features @MMC
- Tolerance Calculator - True Position
- Tolerance Calculator - Spherical True Position
- Hole / Feature Pattern Plot
- GD&T Geometric Dimensioning Tolerancing Basics Training
- GD&T Geometric Dimensioning Tolerancing Intermediate Training
- GDT ASME Y14.5-2009 Applications Training
- G&T Geometric Tolerancing ISO 1101 Training
- Online GD&T Fundamentals Training
