Spherical True Position Tolerance Calculator
This calculator calculates position tolerances utilizing principles and concepts within ASME Y14.5-2009 and ASME Y14.5M - 1994, Geometric Dimensioning and Tolerancing (GD&T).
Open Spherical True Position Calculator
This calculator will convert coordinate measurements to position tolerances. Three (3) inputs are required, See the application illustration at bottom of page.
X Offset - This is the difference between the basic dimension (Drawing) and the actual measurement of the produced part in the X axis direction.
Y Offset - This is the difference between the basic dimension (Drawing) and the actual measurement of the produced part in the Y axis direction.
Z Offset - This is the difference between the basic dimension (Drawing) and the actual measurement of the produced part in the Z axis direction.
Calculated (ACTUAL) Radius True Position - The calculated radius offset
see Spherical True Position Calculator .
Calculated (ACTUAL) Spherical True Position - The calculated spherical positional tolerance diameter zone (2 x R).
Related Resources:
- True Position GD&T Tolerance Calculator
- Tolerance Calculator Floating Fastener Condition
- Tolerance Calculator Fixed Fastener Condition
- Tolerance Calculator Projected Tolerance Zone
- Tolerance Calculator 2 Mating Features @ MMC
- Tolerance Calculator 3 Mating Features @MMC
- Tolerance Calculator - True Position
- Tolerance Calculator - Spherical True Position
- Hole / Feature Pattern Plot
- GD&T Geometric Dimensioning Tolerancing Basics Training
- GD&T Geometric Dimensioning Tolerancing Intermediate Training
- GDT ASME Y14.5-2009 Applications Training
- G&T Geometric Tolerancing ISO 1101 Training
- Online GD&T Fundamentals Training
