Fixed Fastener Condition Projected Tolerance Zone Compensation Calculator
This calculator calculates position tolerances utilizing principles and concepts withinASME Y14.5-2009 and ASME Y14.5M - 1994, Geometric Dimensioning and Tolerancing (GD&T).
For the equations behind this calculator, see:
"Geometric Boundaries"
Interpretation and Application of
Open Description of Variables Used in Calculator
This calculator will calculate the required field compensating for the effects of the fastener projection. Calculations assume a line-line case at tolerance and feature-of-size maximum departure.
Notes:
- Units may be given as inches, mm, meters or whatever.
- Units DO NEED to be consistant (e.g. all inches or all mm).
Related Resources:
