GD&T Two Mating Diameters Tolerance Analysis Calculator at MMC
Calculators
Geometric Dimensioning & Tolerancing GD&T Training
(This calculator requires ajava - enabled browser)
Two Mating Features GD&T True Posistion Calculator This calculator calculates position tolerances utilizing principles and concepts withinASME Y14.5-2009 and ASME Y14.5M - 1994, Geometric Dimensioning and Tolerancing (GD&T).
For the equations behind this calculator, see:
"Geometric Boundaries"
Interpretation and Application of
Notes:
  1. Units may be given as inches, mm, meters or whatever.
  2. Units DO NEED to be consistant (e.g. all inches or all mm).
GD&T Two Mating Features True Position Calculator
Hole Diameter @ MMC
H2
Hole Position Tolerance
Tol_h
Shaft Diameter
D2
Shaft Tolerance
Tol_d
Hole Diameter Datum) @ MMC
H1
Shaft Diameter
(Datum) @ MMC
D1
Clearance
C
Two Mating Diameters True Position
Click on the above image to enlarge
Related Resources:
