Extension Spring Rate Constant Calculator and Formula
This spring rate constant calculator will determine any of the values remaining by changing one of the variables then select the "calculate: button for the selected variable.
This calculator will calculate (estimate) the Spring Rate (k) of a extension spring. Spring rate is best determined by test and measurement techniques.
Equation: k = Gd4/8nD3
k = Spirng Constant, pounds of load per inch of deflection
G = modulus of rigidity of spring material, pounds per square inch
d = wire diameter, inches
n = number of active coils, which is the number of coils subjected to flexure (always less than the total number of coils)
D = mean coil diameter, inches = Outer Diameter - Wire Diameter
Open Extension Spring Rate "k" Constant Calculator
Extension Spring Design Suggestions
- Compression Spring "k" Constant Calculator
- Compression Spring Assembly Operating Life and Reliability Equations and Calculator
- Conical Helical Compression Spring Design Equations and Calculator
- Constant Force Spring Design & Equations
- Helical Compression Springs Engineering and Design
- Extension Spring "k" Constant Calculator
- Extension Spring Calculator
- Extension Spring Normal Load Tolerances load / force Specifications
- Springs Made from Flat Rectangular Cold Rolled Strip Stock Design and Equations Premium Memebrship Required Document
- Flat spring supported on both ends design equations and calculator
- Flat spring cantilevered design equations and calculator
- Flat spring cantilevered design triangular geometry equations and calculator
- Helical Extension Springs Engineering and Design
