Conical Helical Compression Spring Design Equations and Calculator
Conical Helical Compression Spring Design Equations and Calculator.
This is a helical spring in which the coils progressively change in diameter to give increasing stiffness with increasing load. It has the advantage that the compressed height is small.
Stiffness:
Allowable Working Stress (MPa) For Helical Springs (Grade 060A96)
Spring
Wire Diameter (mm)
1 - 3.9
4 - 7.9
8 - 12
Light Duty
590
510
450
Medium Duty
470
410
360
Heavy Duty
400
340
300
Conical helical spring Symbols used:
W = Load (N),
s = Stiffness (N/mm)
G = Shear Modulus (Torsional) of Elasticity (N/m2 or Pa),
τ = Allowable shear stress (Pa),
D1 = smaller diameter (mm),
D2 = larger diameter (mm),
d = wire diameter (mm),
n = number of active coils,
y = Deflection (mm),
C = Coil ratio,
K = Wahl factor,
Mechanical Engineers Databook, Carvil
