Design & Engineering Forum Archive
Engineering Forum | Design Resources | Calculators | Privacy Policy
The following are links to Engineers Edge forum archive. The forums posts are quite old and you will not be able to post new comments to the threads. To post a new forum question or answer visit Engineering Forum.
Speaker Cabinet Design Ryan 04 Dec 2001 00:24:42
Seeking Various Engineering Pros Jeff S 30 Nov 2001 16:26:15
COMPUTER AIDED DESIGN ALAN JONES 29 Nov 2001 12:58:15
Re: COMPUTER AIDED DESIGN 03 Dec 2001 14:31:18
Split washers & Vibration Simon Jones 28 Nov 2001 20:38:35
Re: Split washers & Vibration Sinclare 29 Nov 2001 08:27:49
Displacement Pumps 28 Nov 2001 10:19:50
Engine Balancing Don 28 Nov 2001 02:41:27
JEWELITE BP ALLOY 26 Nov 2001 08:25:30
GEAR STRENGTH MATT 24 Nov 2001 13:02:44
Re: GEAR STRENGTH halfnut 01 Dec 2001 03:30:58
exotic tapers 22 Nov 2001 08:09:21
HVAC efficienty comparison 21 Nov 2001 13:55:49
PROCESS QUALIFICATION IN CASE OF SPOT & MIG WELDING HARPREET SINGH 21 Nov 2001 06:08:38
thickness vanamber 20 Nov 2001 10:24:38
Re: thickness Dan 04 Dec 2001 13:06:59
Re: thickness Dan 04 Dec 2001 13:06:39
Active Vibration Control Denis 17 Nov 2001 18:57:02
Pratical Guide to detailing a part with GD&T 16 Nov 2001 08:15:20
ANSI Flange check calculation 16 Nov 2001 03:17:51
"feasible" True Position Tolerance for bosses on an Automotive Plastic Part 15 Nov 2001 15:44:01
Re: "feasible" True Position Tolerance for bosses on an Automotiv... MacNeal 21 Nov 2001 09:50:56
Re: "feasible" True Position Tolerance for bosses on an Autom... 21 Nov 2001 10:59:30
Vane design on continuous belt system Jim M 12 Nov 2001 17:29:02
Research Student 09 Nov 2001 18:07:24
Magnesium causing corrosion Komo 09 Nov 2001 14:43:42
Re: Magnesium causing corrosion Komo 13 Nov 2001 10:57:09
Re: Magnesium causing corrosion Cragyon 12 Nov 2001 18:39:55
Re: Magnesium causing corrosion Kevin 12 Nov 2001 09:56:06
Units DSB 09 Nov 2001 07:55:02
Re: Units Mike 19 Nov 2001 18:56:36
Re: Units Komo 09 Nov 2001 14:55:34
Re: MIG Welding. DSB 06 Dec 2001 05:20:39
Re: MIG Welding. DSB 06 Dec 2001 05:19:41
welding / casting MGS 07 Nov 2001 03:25:08
threaded screw design 05 Nov 2001 13:41:58
Re: threaded screw design Gersh 04 Dec 2001 13:26:38
Re: threaded screw design Gersh 04 Dec 2001 13:26:08
design calculation on shaft 05 Nov 2001 11:34:39
shaft 05 Nov 2001 11:18:40
STEEL 30 Oct 2001 12:24:33
Re: STEEL EASA 31 Oct 2001 13:02:31
Hi Pro Keys Tommy 24 Oct 2001 15:28:52
Quick Easy Formula for Heat Exchangers Gersh 23 Oct 2001 13:42:07
Re: Quick Easy Formula for Heat Exchangers  08 Nov 2001 15:39:31
v belt info needed rb 22 Oct 2001 23:29:36
Re: v belt info needed Cragyon 23 Oct 2001 14:34:13
Re: v belt info needed rb 23 Oct 2001 16:18:36
3x5x.250 vs. 3x6x.188 extruded aluminum Rowdy Rindfield 22 Oct 2001 18:13:35
Design Tolerance Roanco 22 Oct 2001 12:25:55
Re: Design Tolerance EE 22 Oct 2001 13:48:30
Tension and compression Lindsey 16 Oct 2001 22:14:02
Aluminum Failure Terry Henkel 16 Oct 2001 18:59:36
Craking of metal Kevin Bahadur 16 Oct 2001 11:32:52
welding aluminium fernando 14 Oct 2001 10:37:08
Re: welding aluminium Steve Steven 15 Oct 2001 13:48:35
Tap Source Erby 12 Oct 2001 08:34:38
Re: Tap Source 12 Oct 2001 10:24:23
Re: Tap Source  17 Oct 2001 23:21:35
Flange Problems Kevin Bahadur 10 Oct 2001 14:11:38
Re: Flange Problems Simon Klas 10 Oct 2001 18:17:50
Metal wear Mark 10 Oct 2001 10:58:24
Nylon RFL 4216 M Armando 05 Oct 2001 14:45:21
Mating metals Kevin B 04 Oct 2001 10:40:38
Re: Mating metals Steve Steven 04 Oct 2001 11:48:03
Re: Mating metals Kevin B 05 Oct 2001 08:41:44
Active Vibration Control Denis 03 Oct 2001 10:22:29
v-belt & pulley Den Lee 03 Oct 2001 09:32:58
Mixer HP for high viscosity material Steve Steven 02 Oct 2001 22:59:28
Flat rectangular bar bent to small internal radius Ridw 01 Oct 2001 22:56:57
Re: Flat rectangular bar bent to small internal radius Caleb 04 Oct 2001 20:06:39
morse taper mike 29 Sep 2001 17:10:49
Re: morse taper Cragyon 01 Oct 2001 10:35:22
Re: morse taper m 04 Oct 2001 15:58:54
Re: morse taper mike 04 Oct 2001 15:52:30
Re: morse taper Al 08 Nov 2001 19:39:22
Re: v belt specs 22 Oct 2001 17:22:42
Re: v belt specs Cragyon 23 Oct 2001 12:15:24
Re: morse taper Cragyon 04 Oct 2001 20:13:50
Re: morse taper  05 Oct 2001 15:50:22
A325 Bolt Phil Kelly 27 Sep 2001 14:19:30
vibratory stress releiving 26 Sep 2001 20:36:46
max shear stress of bolt 26 Sep 2001 13:02:37
Re: max shear stress of bolt Rich Smith 26 Sep 2001 13:33:01
Solid-edge l 25 Sep 2001 17:28:41
measuring flatness Michael Joyce 24 Sep 2001 09:46:02
250-500 aarh 21 Sep 2001 19:44:20
Fan solidity Pat March 21 Sep 2001 15:39:49
Stress relieve of 6061 T6 Evgeny 19 Sep 2001 17:49:14
Re: Stress relieve of 6061 T6 Klev 21 Sep 2001 09:16:34
OD Grinding Live Centers 13 Sep 2001 11:09:30
Strength of a Steel Bolt 04 Sep 2001 09:48:47
Re: Strength of a Steel Bolt Futch 04 Sep 2001 10:05:33
shear walls bobbig600 02 Sep 2001 08:36:05
Re: shear walls Cragyon 03 Sep 2001 20:41:51
Shear Wall 01 Sep 2001 19:02:09
Re: Shear Wall Cragyon 03 Sep 2001 20:37:17
inspection prints  31 Aug 2001 13:21:56
Re: inspection prints K. Bramble 31 Aug 2001 15:16:23
Re: inspection prints  04 Sep 2001 11:19:52
Re: inspection prints  06 Sep 2001 07:58:41
Re: inspection prints MH 05 Sep 2001 13:25:14
gudgeon pin material kim 28 Aug 2001 04:58:18
Re: gudgeon pin material Futch 28 Aug 2001 07:19:37
Re: gudgeon pin material t 30 Aug 2001 05:36:11
roundness and concentricity / wall thickness 25 Aug 2001 20:15:31
Re: roundness and concentricity / wall thickness 27 Aug 2001 08:17:36
Re: roundness and concentricity / wall thickness : more info 26 Aug 2001 07:58:35
Re Use of Flypress 23 Aug 2001 09:01:22
Engineering Student Yellow Jacket 23 Aug 2001 08:31:15
Re: Engineering Student Gersh 23 Oct 2001 15:00:56
Re: Engineering Student  28 Aug 2001 09:43:37
Re: Engineering Student Angelo Valenti 27 Aug 2001 14:17:51
Re: Engineering Student mnewton 30 Oct 2001 12:34:44
morse tapers apgar 22 Aug 2001 13:04:26
Re: morse tapers Bill Jones 23 Aug 2001 08:03:04
Re: morse tapers apgar 23 Aug 2001 12:00:50
Re: morse tapers  22 Aug 2001 13:44:57
Skills improvement Evgeny Ivanov 09 Aug 2001 12:54:40
Re: Skills improvement Marshall 10 Aug 2001 11:37:29
Re: Skills improvement Byron Jones 10 Aug 2001 07:31:08
Screw Torque to Push Force conversion P Brown 08 Aug 2001 16:20:43
Re: Screw Torque to Push Force conversion 09 Aug 2001 10:31:56
Re: Screw Torque to Push Force conversion Cragyon 08 Aug 2001 20:35:09
what is the pay rate hungryengineer 07 Aug 2001 19:45:13
Re: what is the pay rate ddunbar 23 Aug 2001 13:12:38
Bonding Agents B Fuller 03 Aug 2001 17:10:52
Humidity Sensor Byron Jones 02 Aug 2001 13:13:43
Re: Humidity Sensor Jim Hereford 14 Nov 2001 05:59:18
How to Calculate the C.G for Offshore Skid Package Babu 30 Jul 2001 20:54:50
Sourcing engineering mechanics book Bry Hibbins 26 Jul 2001 09:17:58
Re: Sourcing engineering mechanics book Paul Jones 26 Jul 2001 15:15:13
ME PE Exam MGM 20 Jul 2001 19:40:05
Re: ME PE Exam Cragyon 24 Jul 2001 11:18:36
Re: ME PE Exam Tom Larson, PE 23 Jul 2001 18:00:10
Re: ME PE Exam Jack Pritchet 23 Jul 2001 13:13:47
Active Vibration control.... n 13 Jul 2001 00:43:48
Re: Active Vibration control.... Denis 03 Oct 2001 10:19:44
screws mike 12 Jul 2001 21:13:04
Ejector design for cards (pcb) Extraction and insertion forces 10 Jul 2001 12:53:03
Re: Ejector design for cards (pcb) 24 Oct 2001 14:07:01
Re: Ejector design for cards (pcb) Cragyon 10 Jul 2001 16:06:28
Re: Ejector design for cards (pcb) Kevin Mark. E-mail: KMark@luxcore.com 11 Jul 2001 15:54:22
Electrical Generators bmckjnr@hotmail.com 02 Jul 2001 07:14:22
Re: Electrical Generators 30 Aug 2001 05:22:41
Internal  Gear Pump Crescent type  for dispensing  Gasoline  Dilip Manohar. 01 Jul 2001 12:10:32
Re: Internal  Gear Pump Crescent type  for dispensing  Gasoline 31 Aug 2001 00:42:46
progressive tooling jim roots 26 Jun 2001 14:37:14
Re: progressive tooling - Check These Out Cragyyon 28 Jun 2001 11:26:20
Re: progressive tooling - Check These Out jim roots 11 Jul 2001 15:50:33
Re: progressive tooling 28 Jun 2001 07:36:54
Re: progressive tooling  28 Jun 2001 10:54:52
Investment Casting BK 26 Jun 2001 07:56:03
Re: Investment Casting 27 Jul 2001 13:59:53
SCREW clara27@ms27.hinet.net 22 Jun 2001 02:10:07
Re: SCREW Cragyon 22 Jun 2001 08:51:59
Cutting Resisitance E. L. Murray 15 Jun 2001 13:44:27
Re: Cutting Resistance 18 Jun 2001 08:15:16
Coefficient of Friction Steve 11 Jun 2001 00:23:06
Metric Fasteners Distributor Mark 05 Jun 2001 16:55:28
Re:Metric fasteners 26 Jul 2001 19:22:47
project Schwabby 05 Jun 2001 16:37:48
Re: Bolt Thread Friction 25 Sep 2001 10:33:18
nikkiso centrifugal can pumps 30 May 2001 09:07:19
Re: nikkiso centrifugal can pumps DF 30 May 2001 10:13:11
Welding on fuel storage Carl 25 May 2001 12:24:05
Liquid Shrinkage of Castings Baluff 24 May 2001 21:18:06
Re: Liquid Shrinkage of Castings K. Bramble 29 Jul 2001 20:52:47
TOOL DESIGN 23 May 2001 06:54:19
Re: TOOL DESIGN Cragyon 23 May 2001 08:05:04
CAD Study W. King 22 May 2001 08:02:24
Re: CAD Study M. Kuznicki 15 Nov 2001 16:21:25
Re: CAD Study M. Kuznicki 15 Nov 2001 16:20:46
Re: CAD Study Gersh 23 Oct 2001 15:09:08
Re: CAD Study MECHMAN 26 Sep 2001 16:41:17
Vibrational analysis and stiffness 18 May 2001 15:01:26
Re: Vibrational analysis and stiffness DF 18 May 2001 15:51:43
V-belts 17 May 2001 15:57:14
Re: V-belts kipp 19 May 2001 13:13:00
Re: V-belts Futch_J 18 May 2001 16:14:59
Calculation Fixed Fastener Torxman 17 May 2001 12:41:32
Re: Calculation Fixed Fastener Duane Putnam 22 Jun 2001 14:58:41
Re: Carr Lane Bob Curtis 28 Sep 2001 23:03:36
Re: Carr Lane Hoang Nguyen 12 Nov 2001 12:35:05
Re: Calculation Fixed Fastener Kelly Bramble - Engineers Edge 13 Jun 2001 15:24:03
Thompsons Flex Coupling Dave Parrish 14 May 2001 08:38:30
Re: Thompsons Flex Coupling Glenn Thompson 20 Oct 2001 10:37:42
Re: Thompsons Flex Coupling rt3536@aol.com 18 May 2001 09:57:13
DXF to ProE carl 09 May 2001 08:48:16
Re: DXF to ProE CPL 11 Jul 2001 23:07:23
VIBRATION 07 May 2001 03:47:54
Re: VIBRATION S.H. 19 Jun 2001 16:19:39
Re: VIBRATION Larson 07 May 2001 09:05:07
Help needed for research Mark Lees 05 May 2001 18:16:56
Feed - Rate Aluminum 04 May 2001 15:48:34
Re: Feed - Rate Aluminum Cragyon 14 May 2001 14:15:39
Cad For Sheet Metal 01 May 2001 08:10:58
Re: Cad For Sheet Metal Gersh 23 Oct 2001 15:12:45
Re: Cad For Sheet Metal shiva 31 May 2001 01:14:07
Re: Cad For Sheet Metal 23 May 2001 06:45:11
Re: Cad For Sheet Metal 03 May 2001 20:47:21
Re: Cad For Sheet Metal 14 May 2001 22:02:01
Re: Cad For Sheet Metal   04 May 2001 07:49:44
Re: Cad For Sheet Metal 02 May 2001 21:10:12
Helicoils & Tangless Threaded Inserts PB 30 Apr 2001 08:37:26
Re: Helicoils & Tangless Threaded Inserts C. Carmichael 03 May 2001 08:10:26
Re: Helicoils & Tangless Threaded Inserts 16 Jul 2001 15:57:38
Cylindrical Boring Bar Deflection Nathan 26 Apr 2001 10:08:09
Re: Cylindrical Boring Bar Deflection Lawrence Sullivan 27 Apr 2001 08:27:14
Miniature Screw Sizes Michael 25 Apr 2001 04:42:34
Re: Miniature Screw Sizes Bob Curtis 29 Sep 2001 00:00:18
Re: Miniature Screw Sizes Bob Curtis 29 Sep 2001 00:00:02
Re: Miniature Screw Sizes5 Jul 2001 14:34:08
Re: Miniature Screw Sizes Cragyon 25 Apr 2001 08:16:53
Pig Iron 24 Apr 2001 18:44:41
Re: Pig Iron Aamir Khalid 01 May 2001 13:46:54
Re: Pig Iron  25 Apr 2001 08:20:12
Re: Pig Iron Michael 25 Apr 2001 04:50:56
Extrusion Vendor  24 Apr 2001 14:01:28
Re: Extrusion Vendor Dave P. 25 Apr 2001 16:05:06
GD&T History L.D. Dutcher 22 Apr 2001 21:01:33
Re: GD&T History Duane Putnam 22 Jun 2001 15:01:49
Re: GD&T History Kelly Bramble 24 Apr 2001 08:19:53
Metal Injection Moulding t 22 Apr 2001 15:43:16
Re: Metal Injection Moulding Cragyon 23 Apr 2001 10:14:59
Metal Injection Moulding 22 Apr 2001 15:41:43
Re: Metal Injection Moulding  10 Aug 2001 03:22:30
Re: Metal Injection Moulding 23 May 2001 06:51:40
Re: Metal Injection Moulding  12 Jul 2001 01:33:19
Transmission Case  19 Apr 2001 11:42:36
Re: Transmission Case Caleb T. 20 Apr 2001 13:14:54
Solid Edge Diane 4/10/2001 10:55:22 PM
Re: Solid Edge   4/11/2001 12:56:21 PM
Heating of Clutch Plates James Beckerwerth 4/10/2001 1:31:55 PM
Re: Heating of Clutch Plates James Waltz 06 May 2001 21:01:49
freezing in a vacuum Scott Fortuna 4/7/2001 10:27:04 PM
Re: freezing in a vacuum 02 Jul 2001 07:00:00
Saddle Ket Pempsell 4/6/2001 8:52:44 AM
Re: Saddle Ket Cragy 4/9/2001 2:08:48 PM
The Taylor Principle Gary 4/4/2001 11:11:24 AM
Re: The Taylor Principle Kelly Bramble 4/4/2001 2:38:56 PM
Re: The Taylor Principle Marshall 19 Jun 2001 13:30:05
Tooling material Evgeny Ivanov 4/3/2001 2:39:35 PM
Re: Tooling material Engineers Edge 4/3/2001 10:21:13 PM
Re: Tooling material T. Newbury 4/3/2001 4:35:46 PM
Bearing difference. Evgeny Ivanov, 4/1/2001 7:11:03 PM
Re: Bearing difference. 24 Oct 2001 14:18:21
Re: Bearing difference. 4/2/2001 1:20:51 PM
PC Boards  3/30/2001 10:12:47 AM
Re: PC Boards Kutz 4/2/2001 1:27:35 PM
Rivet Hole Design   3/28/2001 2:42:50 PM
Re: Rivet Hole Design C. Wiskocil 3/29/2001 12:19:51 PM
Flat Washer 3/27/2001 9:39:37 PM
Re: Flat Washer Jeff H. 3/28/2001 7:55:15 AM
CTE Danny 3/27/2001 3:25:12 PM
Re: CTE Jeff H 3/28/2001 7:48:27 AM
About Foundry................ JD 3/27/2001 8:34:22 AM
Re: About Foundry................ trr 31 Jul 2001 13:16:58
alloy and temper,T42,T3. Evgeny Ivanov 3/25/2001 3:01:05 AM
Re: alloy and temper,T42,T3. Perry Hope 3/25/2001 9:14:56 AM
Steel Bolts Ganesh 3/23/2001 7:40:01 AM
Re: Steel Bolts Simon A. 3/26/2001 2:13:07 PM
Re: Steel Bolts JT 3/23/2001 11:43:08 PM
The references of the making wire for all wire products Sutan 3/22/2001 11:39:18 PM
GD&T in the Real World Lindsay 3/22/2001 12:36:57 PM
Re: GD&T in the Real World Bob Bartley 28 Nov 2001 15:36:11
Re: GD&T in the Real World Cragyon 07 May 2001 14:00:40
Re: GD&T in the Real World  05 May 2001 16:02:24
