Solder Joint - Bevel Joint Calculator / Formulae
Solder tapered angle joint equations and calculator for stress intension, stress in shear, tensile stress in brazed joint.
Preview Solder Joint Bevel Surfaces Strength Calculator
Allowed Tapered Joint stress in tension loading equation:
σA = SU / kT
Joint allowable stress in shear loading equation:
τA = SUS / ks
Tensile stress in joint loading equation:
σ = [ F · sin2 ( ( α · π)] / 180)) / ( b · s )
Shear stress in joint loading equation:
τ = [ F · sin ( ( α · π) / 180)) · cos ( ( α · π)] / 180 )/ ( b · s )
Strength check
σ ≤ σA & T ≤ TA
Minimum thickness of connected parts
smin = max{s1, s2}
where:
s1 = [ F · sin2 ( ( α · π ) / 180 ) ] / ( b · σA)
s2 = [ F · sin ( ( α · π ) / 180 ) · cos ( ( α · π ) / 180 )] / ( b · τA)
where:
SU = joint strength in tension of solder [psi, MPa],
kT = tension safety coefficient (typically 2 or greater),
SUS = joint strength in shear of solder [psi, MPa],
kS = shear safety coefficient (typically 2 or greater),
F = transferred force [lb, N],
b = width (minimum) of connected parts [in, mm],
s = thickness (minimum) of connected parts (in, mm],
α = angle of bevel (deg.).
Kent's Machine Engineers Handbook, 12th Edition Design and Production, 1950 Colin Carmichael
Related web pages:
