Composite Position Tolerance Calculator GD&T for External FOS
Mechanical Engineering Tolerances Resources
GD&T Composite Position Tolerance Calculator for Dimensional Inspection:
External Feature of Size - post, tab, pipe, etc...
Assumptions:
- Applies to an External Features of Size (Tab, Boss Projection etc..)
- PLTZF tolerance applied at MMC
- FRTZF tolerance applied at MMC
- All dimensional unit applied with uniform units - all inches, mm, m, etc.
- Datum applied at RFS
- Datums are normally othogonal to FOS for PLTZF
- Complex, non othogonal datums not supported
- FRTZF datum is perpendicular to features
- X and Y measurements taken with datum's established
- Up to fifteen (15) features can be calculated
- Hole feature #1 is used as the origin for the FRTZF position tolerance calculations
Preview:
- Composite Position Tolerance Calculator for External FOS PLTZF
- Composite Position Tolerance Calculator for External FOS FRTZF
For information on the equations used in this calculator, see:
Geometric Boundaries, II - The Interpretation and Application of GD&T per. ASME Y14.5-2009
