Heat Loss from Bare Copper Tube
Heat Loss from Bare Copper Tube to Still Air at 80°F, Btu/h· ft
Also See:
Pipe Size,
in |
Pipe Inside Temperature, °F
120 |
150 |
180 |
210 |
240 |
3/8 |
10.6 |
20.6 |
31.9 |
44.2 |
57.5 |
1/2 |
12.7 |
24.7 |
38.2 |
53.1 |
69.2 |
3/4 |
16.7 |
32.7 |
50.7 |
70.4 |
91.9 |
1 |
20.7 |
40.5 |
62.9 |
87.5 |
114 |
1 1/4 |
24.6 |
48.3 |
74.9 |
104 |
136 |
1 1/2 |
28.5 |
55.9 |
86.9 |
121 |
158 |
2 |
36.1 |
71.0 |
110 |
154 |
201 |
2 1/2 |
43.7 |
86.0 |
134 |
187 |
244 |
3 |
51.2 |
101 |
157 |
219 |
287 |
3 1/2 |
58.7 |
116 |
180 |
251 |
329 |
4 |
66.1 |
130 |
203 |
283 |
371 |
5 |
80.9 |
159 |
248 |
347 |
454 |
6 |
95.6 |
188 |
294 |
410 |
538 |
8 |
125 |
246 |
383 |
536 |
703 |
10 |
154 |
303 |
473 |
661 |
867 |
12 |
183 |
360 |
562 |
786 |
1031 |
Conversion
Qty |
Reference Unit |
is equal to |
Conversion Factor |
Unit |
1 |
BTU/hour square foot °F |
1 |
1 |
0.000135622991 |
calorie/second square centimeter °C |
1 |
1 |
CHU/hour square foot °C |
1 |
5.678263398 |
joule/second square meter K |
1 |
0.45359237 |
kilocalorie/hour square foot °C |
1 |
4.88242768 |
kilocalorie/hour square meter °C |
1 |
5.678263398 |
watt/square meter K |
1 |
5.678263398 |
watt/square meter °C |
Conversion of units
Qty | Unit | is equal to |
Conversion Factor |
Reference Unit |
1 | BTU/hour square foot °F | = | 1 | BTU/hour square foot °F |
1 | calorie/second square centimeter °C | = | 7373.3810965421 | |
1 | CHU/hour square foot °C | = | 1 | |
1 | joule/second square meter K | = | 0.17611018191798 | |
1 | kilocalorie/hour square foot °C | = | 2.2046226007073 | |
1 | kilocalorie/hour square meter °C | = | 0.20481614157061 | |
1 | watt/square meter K | = | 0.17611018191798 | |
1 | watt/square meter °C | = | 0.17611018191798 |
- Heat Loss from Bare Steel Pipe
- Heat Loss Insulated Pipe Equation and Calculator
- Heat Loss or Gain From Pipe Excel Spreadsheet Calculator
- Heat Loss from Pipe Outdoors
- Heat Loss from Ducts Equations and Calculator
- HVAC Air Duct Flow Resistance Chart
- Spiral Duct Machine Review
- Duct Design Air Flow Velocities
- Thermal Linear Expansion of AISI 303 Stainless Steel
- Pipe Expansion Thermal Loop Equations and Calculator
- Coefficients Linear Thermal Expansion
- Compression Tension Stress Linear Thermal Expansion Equation and Calculator
- Linear Thermal Expansion Equation and Calculator
- Thermal Properties of Metals, Conductivity, Thermal Expansion, Specific Heat
- ASHRAE Fundamental Handbook, 2019
