Heat Loss from Bare Steel Pipe
Heat Loss from Bare Steel Pipe to Still Air at 80°F, Btu/h· ft
Also See:
Pipe Size, in |
Pipe Inside Temperature, °F |
180 |
280 |
380 |
480 |
580 |
1/2 |
56.3 |
138 |
243 |
377 |
545 |
3/4 |
68.1 |
167 |
296 |
459 |
665 |
1 |
82.5 |
203 |
360 |
560 |
813 |
1 1/4 |
102 |
251 |
446 |
695 |
1010 |
1 1/2 |
115 |
283 |
504 |
787 |
1150 |
2 |
141 |
350 |
623 |
974 |
1420 |
2 1/2 |
168 |
416 |
743 |
1160 |
1700 |
3 |
201 |
499 |
891 |
1400 |
2040 |
3 1/2 |
228 |
565 |
1010 |
1580 |
2310 |
4 |
254 |
631 |
1130 |
1770 |
2590 |
4 1/2 |
281 |
697 |
1250 |
1960 |
2860 |
5 |
313 |
777 |
1390 |
2180 |
3190 |
6 |
368 |
915 |
1640 |
2580 |
3770 |
7 |
421 |
1040 |
1880 |
2950 |
4310 |
8 |
473 |
1180 |
2110 |
3320 |
4860 |
9 |
525 |
1310 |
2340 |
3680 |
5400 |
10 |
583 |
1450 |
2610 |
4100 |
6000 |
12 |
686 |
1710 |
3070 |
4830 |
7090 |
14 |
747 |
1860 |
3340 |
5260 |
7720 |
16 |
850 |
2120 |
3810 |
6000 |
8790 |
18 |
953 |
2380 |
4270 |
6730 |
9870 |
20 |
1060 |
2630 |
4730 |
7460 |
10,950 |
24 |
1260 |
3150 |
5660 |
8920 |
13,100 |
Conversion
Qty |
Reference Unit |
is equal to |
Conversion Factor |
Unit |
1 |
BTU/hour square foot °F |
1 |
1 |
0.000135622991 |
calorie/second square centimeter °C |
1 |
1 |
CHU/hour square foot °C |
1 |
5.678263398 |
joule/second square meter K |
1 |
0.45359237 |
kilocalorie/hour square foot °C |
1 |
4.88242768 |
kilocalorie/hour square meter °C |
1 |
5.678263398 |
watt/square meter K |
1 |
5.678263398 |
watt/square meter °C |
Conversion of units
Qty | Unit | is equal to |
Conversion Factor |
Reference Unit |
1 | BTU/hour square foot °F | = | 1 | BTU/hour square foot °F |
1 | calorie/second square centimeter °C | = | 7373.3810965421 | |
1 | CHU/hour square foot °C | = | 1 | |
1 | joule/second square meter K | = | 0.17611018191798 | |
1 | kilocalorie/hour square foot °C | = | 2.2046226007073 | |
1 | kilocalorie/hour square meter °C | = | 0.20481614157061 | |
1 | watt/square meter K | = | 0.17611018191798 | |
1 | watt/square meter °C | = | 0.17611018191798 |
- Heat Loss Insulated Pipe Equation and Calculator
- Heat Loss or Gain From Pipe Excel Spreadsheet Calculator
- Heat Loss from Pipe Outdoors
- Heat Loss from Ducts Equations and Calculator
- HVAC Air Duct Flow Resistance Chart
- Spiral Duct Machine Review
- Duct Design Air Flow Velocities
- Thermal Linear Expansion of AISI 303 Stainless Steel
- Pipe Expansion Thermal Loop Equations and Calculator
- Coefficients Linear Thermal Expansion
- Compression Tension Stress Linear Thermal Expansion Equation and Calculator
- Linear Thermal Expansion Equation and Calculator
- Thermal Properties of Metals, Conductivity, Thermal Expansion, Specific Heat
- ASHRAE Fundamental Handbook, 2019
