Toggle Mechanism Ninety Degree Equations and Calculator
Manufacturing Toggle Mechanism Ninety Degree Pivot Lock Formula and Calculator
Preview: Toggle Mechanism Ninety Degree Pivot Lock Design Calculator
Figure 1 Toggle Mechanism
Q = P · ( l / l1 ) · ( 1 / n )
P = Q / [ ( l / l1 ) · ( 1 / n ) ]
Q = force applied to handle. lbf, (N)
P = clamping force, lbf. (N)
l = length, in, (mm)
l1 = length, in, (mm)
n = efficiency coefficient,
0.98 to
0.84,
determined by frictional losses in pivots and bearings,
Handbook of Machining and Metalworking Calculations
Ron A. Walsh
2001
- Toggle Mechanism Center Locking Design Formula and Calculator
- Toggle Clamp Mechanism no. 5 Formula and Calculator
- Pivot Arm Toggle Formulae and Calculator
- Triangular Clamping Toggle Design Formula and Calculator
- Work Holding Toggle Mechanism Calculations
- Toggle Clamp Equations and Calculator
- Toggle Clamps Animation
- Toggle Clamping Mechanism Formula and Calculator
- Mechanisms in Modern Engineering Design
- Theory of Mechanisms and Machines
- Ingenious Mechanisms Volume I for Designers and Inventors
- Ingenious Mechanisms Volume II for Designers and Inventors
- Simple Mechanical Levers Equations and Calculators
- Adding Forces by the Parallelogram Resultant of Two Forces Equation and Calculator
- Geneva Mechanism External Design Calculator and Equations
