Toggle Mechanism Center Locking Design Formula and Calculator
Manufacturing Toggle Mechanism Center Locking Design Formula and Calculator
Preview: Toggle Mechanism Center Locking Design Calculator
Figure 1 Toggle Mechanism
Q = 2 · P · tan(α + β ) · tan α1
β = arcsin fo
Eq. 3
P = Q / ( 2 · tan(α + β ) · tan α1 )
Q = force applied to handle. lbf, (N)
P = clamping force, lbf. (N)
α = angle, deg.
fo = coefficient of friction (axles and pivot pins)
0.1 to 0.15
Handbook of Machining and Metalworking Calculations
Ron A. Walsh
2001
- Toggle Clamp Mechanism no. 5 Formula and Calculator
- Pivot Arm Toggle Formulae and Calculator
- Triangular Clamping Toggle Design Formula and Calculator
- Work Holding Toggle Mechanism Calculations
- Toggle Clamp Equations and Calculator
- Toggle Clamps Animation
- Toggle Clamping Mechanism Formula and Calculator
- Mechanisms in Modern Engineering Design
- Theory of Mechanisms and Machines
- Ingenious Mechanisms Volume I for Designers and Inventors
- Ingenious Mechanisms Volume II for Designers and Inventors
- Simple Mechanical Levers Equations and Calculators
- Adding Forces by the Parallelogram Resultant of Two Forces Equation and Calculator
- Geneva Mechanism External Design Calculator and Equations
