Minimum Length of Thread Engagement Formula and Calculator
Fastener and Thread Design Menu
ISO Hardware Engineering Data
ANSI Hardware Engineering Data
Mechanics / Strength of Materials Menu
Screw Thread Strength Calculations FED-STD-H28/2B, 1991
and Machinery's Handbook twenty fourth Edition.
These calculations strictly apply to UN thread series however, may be used for metric series threads. In practice when the values are calculated the value for the screw shear strength is similar to the very convenient formula provided above.
Open Calculator:
Minimum Length of Thread Engagement Calculator Per FED-STD-H28/2B
Length of Thread
Le       = Fastener thread engagement
At         = Tensile Stress Area
Knmax = Maximum minor diameter of internal thread.
Esmin  = Minimum pitch diameter of external thread.
n        = Number of threads per inch
Threaded Hole / Fastener Ratio:
Open - ISO & fed H28nThread / Fastener Ratio and Length Calculator
If material in which the female thread is tapped is significantly weaker that the screw material then J must be evaluated.
Where;
As   = Shear area of the external thread (screw or fastener)
An   = Shear area of the internal thread ( hole )
If the value of J is greater than 1 then the length of engagement must be increased to at least
Le = Fastener Thread Engagement
