Minimum Thread Engagement Equation and Calculator ISO
Fastener and Thread Design Menu
ISO Hardware Data
ANSI Hardware Data
Mechanics / Strength of Materials Menu
The screw should fail before the thread strips. For this, it is necessary the shear area of the threaded feature be at least 2 times the tensile area. (Assuming the threaded feature is of the identical material).
Le = Minimum Thread Engagement Length
At = Tensile Stress Area
D = Major Diameter of fastener (screw)
p = 1 / Number of threads per inch (n)
Open Minimum ISO Thread Engagement Calculator
Threaded Hole / Fastener Ratio:
Open - ISO Thread / Fastener Ratio and Length Calculator
This assumes that the male and female thread materials have the same strength. If the Female Material strength is lower i.e. J as calculated below is greater than 1 then the length of engagement must be increased to prevent the female thread stripping
J = Thread Engagement Ratio
If the value of J is greater than 1 then the length of engagement must be increased to at least
le = Thread Engagement Length
