Structural Steel Wide Flange Section Properties BS4: Part 1
Structural Materials Menu
Engineering Materials Menu
Structural Steel Wide Flange Section Properties BS4: Part 1 | European Standard Wide Flange H Beam.
This European Standard specifies requirements for the nominal dimensions of Structural Steel Wide Flange I Beams.
Shape Designation |
Height |
Width |
Web |
Flange |
Internal Radius |
Area of Section |
d (mm) |
bf (mm) |
tw (mm) |
tf (mm) |
r (mm) |
A (cm2) |
914 x 419 x 388
921
420.5
21.4
36.6
24.1
494
914 x 419 x 343
911.8
418.5
19.4
32
24.1
437
914 x 305 x 289
926.6
307.7
19.5
32
19.1
368
914 x 305 x 253
918.4
305.5
17.3
27.9
19.1
323
914 x 305 x 224
910.4
304.1
15.9
23.9
19.1
286
914 x 305 x 201
903
303.3
15.1
20.2
19.1
256
838 x 292 x 226
850.9
293.8
16.1
26.8
17.8
289
838 x 292 x 194
840.7
292.4
14.7
21.7
17.8
247
838 x 292 x 176
834.9
291.7
14
18.8
17.8
224
762 x 267 x 197
769.8
268
15.6
25.4
16.5
251
762 x 267 x 173
762.2
266.7
14.3
21.6
16.5
220
762 x 267 x 147
754
265.2
12.8
17.5
16.5
187
762 x 267 x 134
750
264.4
12
15.5
16.5
171
686 x 254 x 170
692.9
255.8
14.5
23.7
15.2
217
686 x 254 x 152
687.5
254.5
13.2
21
15.2
194
686 x 254 x 140
683.5
253.7
12.4
19
15.2
178
686 x 254 x 125
677.9
253
11.7
16.2
15.2
159
610 x 305 x 238
635.8
311.4
18.4
31.4
16.5
303
610 x 305 x 179
620.2
307.1
14.1
23.6
16.5
228
610 x 305 x 149
612.4
304.8
11.8
19.7
16.5
190
610 x 229 x 140
617.2
230.2
13.1
22.1
12.7
178
610 x 229 x 125
612.2
229
11.9
19.6
12.7
159
610 x 229 x 113
607.6
228.2
11.1
17.3
12.7
144
610 x 229 x 101
602.6
227.6
10.5
14.8
12.7
129
533 x 210 x 122
544.5
211.9
12.7
21.3
12.7
155
533 x 210 x 109
539.5
210.8
11.6
18.8
12.7
139
533 x 210 x 101
536.7
210
10.8
17.4
12.7
129
533 x 210 x 92
533.1
209.3
10.1
15.6
12.7
117
533 x 210 x 82
528.3
208.8
9.6
13.2
12.7
105
457 x 191 x 98
467.2
192.8
11.4
19.6
10.2
125
457 x 191 x 89
463.4
191.9
10.5
17.7
10.2
114
457 x 191 x 82
460
191.3
9.9
16
10.2
104
457 x 191 x 74
457
190.4
9
14.5
10.2
94.6
457 x 191 x 67
453.4
189.9
8.5
12.7
10.2
85.5
457 x 152 x 82
465.8
155.3
10.5
18.9
10.2
105
457 x 152 x 74
462
154.4
9.6
17
10.2
94.5
457 x 152 x 67
458
153.8
9
15
10.2
85.6
457 x 152 x 60
454.6
152.9
8.1
13.3
10.2
76.2
457 x 152 x 52
449.8
152.4
7.6
10.9
10.2
66.6
406 x 178 x 74
412.8
179.5
9.5
16
10.2
94.5
406 x 178 x 67
409.4
178.8
8.8
14.3
10.2
85.5
406 x 178 x 60
406.4
177.9
7.9
12.8
10.2
76.5
406 x 178 x 54
402.6
177.7
7.7
10.9
10.2
69
406 x 140 x 46
403.2
142.2
6.8
11.2
10.2
58.6
406 x 140 x 39
398
141.8
6.4
8.6
10.2
49.7
356 x 171 x 67
363.4
173.2
9.1
15.7
10.2
85.5
356 x 171 x 57
358
172.2
8.1
13
10.2
72.6
356 x 171 x 51
355
171.5
7.4
11.5
10.2
64.9
356 x 171 x 45
351.4
171.1
7
9.7
10.2
57.3
356 x 127 x 39
353.4
126
6.6
10.7
10.2
49.8
356 x 127 x 33
349
125.4
6
8.5
10.2
42.1
305 x 165 x 54
310.4
166.9
7.9
13.7
8.9
68.8
305 x 165 x 46
306.6
165.7
6.7
11.8
8.9
58.7
305 x 165 x 40
303.4
165
6
10.2
8.9
51.3
305 x 127 x 48
311
125.3
9
14
8.9
61.2
305 x 127 x 42
307.2
124.3
8
12.1
8.9
53.4
305 x 127 x 37
304.4
123.4
7.1
10.7
8.9
47.2
305 x 102 x 33
312.7
102.4
6.6
10.8
7.6
41.8
305 x 102 x 28
308.7
101.8
6
8.8
7.6
35.9
305 x 102 x 25
305.1
101.6
5.8
7
7.6
31.6
254 x 146 x 43
259.6
147.3
7.2
12.7
7.6
54.8
254 x 146 x 37
256
146.4
6.3
10.9
7.6
47.2
254 x 146 x 31
251.4
146.1
6
8.6
7.6
39.7
254 x 102 x 28
260.4
102.2
6.3
10
7.6
36.1
254 x 102 x 25
257.2
101.9
6
8.4
7.6
32
254 x 102 x 22
254
101.6
5.7
6.8
7.6
28
203 x 133 x 30
206.8
133.9
6.4
9.6
7.6
38.2
203 x 133 x 25
203.2
133.2
5.7
7.8
7.6
32
203 x 102 x 23
203.2
101.8
5.4
9.3
7.6
29.4
178 x 102 x 19
177.8
101.2
4.8
7.9
7.6
24.3
152 x 89 x 16
152.4
88.7
4.5
7.7
7.6
20.3
127 x 76 x 13
127
76
4
7.6
7.6
16.5
