Structural A36 Steel Channel Section Properties Table Chart
Structural Materials Menu
Engineering Materials Menu
ASTM Steel Channel Section Properties various sizes ranging C3 - C15
ASTM A36 channel is one of the most widely used carbon steels in industry. A36 steel it is weldable, formable, and machinable. Galvanizing the steel increases its corrosion-resistance.
The following chart table gives cross section engineering data for ASTM Structural Steel Channel as follows:
- Weight per foot
- Cross Section Area
- Area Moment of Inertia
- Wall Thickness
Related Resources:
- AISC, ASTM Angle Unequal Leg ( Aluminum )
- AISC, ASTM Angle Equal Leg ( Aluminum )
- AISC, ASTM Angle Unequal Leg ( Steel )
- Structural Steel Angle Section Properties, Unequal Leg BSI BS EN 10056
- Structural Steel Angle Section Properties, Equal Leg BSI BS EN 10056
in x lb/ft |
Area (in2) |
d (in) |
bf (in) |
tf (in) |
tw (in) |
Ixx (in4) |
Iyy (in4) |
xb (in) |
C15x50 |
14.7 |
15 |
3.716 |
0.65 |
0.716 |
404 |
11 |
0.798 |
C15x40 |
11.8 |
15 |
3.52 |
0.65 |
0.52 |
349 |
9.23 |
0.777 |
C15x33.9 |
9.96 |
15 |
3.4 |
0.65 |
0.4 |
315 |
8.13 |
0.787 |
C12x30 |
8.82 |
12 |
3.17 |
0.501 |
0.51 |
162 |
5.14 |
0.674 |
C12x25 |
7.35 |
12 |
3.047 |
0.501 |
0.387 |
144 |
4.47 |
0.674 |
C12x20.7 |
6.09 |
12 |
2.942 |
0.501 |
0.282 |
129 |
3.88 |
0.698 |
C10x30 |
8.82 |
10 |
3.033 |
0.436 |
0.673 |
103 |
3.94 |
0.649 |
C10x25 |
7.35 |
10 |
2.886 |
0.436 |
0.526 |
91.2 |
3.36 |
0.617 |
C10x20 |
5.88 |
10 |
2.739 |
0.436 |
0.379 |
78.9 |
2.81 |
0.606 |
C10x15.3 |
4.49 |
10 |
2.6 |
0.436 |
0.24 |
67.4 |
2.28 |
0.634 |
C9x20 |
5.88 |
9 |
2.648 |
0.413 |
0.448 |
60.9 |
2.42 |
0.583 |
C9x15 |
4.41 |
9 |
2.485 |
0.413 |
0.285 |
51 |
1.93 |
0.586 |
C9x13.4 |
3.94 |
9 |
2.433 |
0.413 |
0.233 |
47.9 |
1.76 |
0.601 |
C8x13.75 |
4.04 |
8 |
2.343 |
0.39 |
0.303 |
36.1 |
1.53 |
0.553 |
C8x11.5 |
3.38 |
8 |
2.26 |
0.39 |
0.22 |
32.6 |
1.32 |
0.571 |
C7x14.75 |
4.33 |
7 |
2.299 |
0.366 |
0.419 |
27.2 |
1.38 |
0.532 |
C7x12.25 |
3.6 |
7 |
2.194 |
0.366 |
0.314 |
24.2 |
1.17 |
0.525 |
C7x9.8 |
2.87 |
7 |
2.09 |
0.366 |
0.21 |
21.3 |
0.968 |
0.54 |
C6x13 |
3.83 |
6 |
2.157 |
0.343 |
0.437 |
17.4 |
1.05 |
0.514 |
C6x10.5 |
3.09 |
6 |
2.034 |
0.343 |
0.314 |
15.2 |
0.866 |
0.499 |
C6x8.2 |
2.4 |
6 |
1.92 |
0.343 |
0.2 |
13.1 |
0.693 |
0.511 |
C5x9 |
2.64 |
5 |
1.885 |
0.32 |
0.325 |
8.9 |
0.632 |
0.478 |
C5x6.7 |
1.97 |
5 |
1.75 |
0.32 |
0.19 |
7.49 |
0.479 |
0.484 |
C4x7.25 |
2.13 |
4 |
1.721 |
0.296 |
0.321 |
4.59 |
0.433 |
0.459 |
C4x5.4 |
1.59 |
4 |
1.584 |
0.296 |
0.184 |
3.85 |
0.319 |
0.457 |
C3x6 |
1.76 |
3 |
1.596 |
0.273 |
0.356 |
2.07 |
0.305 |
0.455 |
C3x5 |
1.47 |
3 |
1.498 |
0.273 |
0.258 |
1.85 |
0.247 |
0.438 |
C3x4.1 |
1.21 |
3 |
1.41 |
0.273 |
0.17 |
1.66 |
0.197 |
0.436 |
