Helical Compression Spring Design Equations and Calculator
This Helical Compression Spring Design Equation will determine force from the given variables.
Force (F) = k(DStanding - DDeflected)
F = Force exerted on spring (lbs)DStanding = Free length of spring (inches)
DDeflected= Length of spring with force applied (inches)
k = Spring constant determined by experiment or calculation (Calculate k Constant)
Open -> Helical Compression Spring Design Calculator
Compression Spring Design Suggestions:
Spring rate can be measured by taking the difference in force at 80% maximum deflection and 20% minimum deflection and dividing by the difference in deflection. The spring rate tends to be constant over the central 60 percent of the deflection range. Because of end-coil effects, the first 20% of deflection range has a considerably lower spring rate. The final 20% of deflection shows considerably higher spring rate. When designing for a particular spring, design for critical loads and rates to be within the central 60% deflection range. Standard and custom springs are available.
- Design Equations of Belleville Washer Springs
- Leaf Spring Design and Engineering Strength of Materials
- Constant Force Spring Design and Equations
- Coil Spring Engineering Design Application
- Helical Compression Spring Design Equations and Calculator
- Shock Loading Helical Springs Formulas and Calculator
- Helical Spring Fatigue Loading and Factor of Safety Formulas and Calculator
- Series and Parallel Spring Forces Calculator
