Spring Pins, Roll Pins, Split Pins Size Table ANSI/ASME B18.8.2
The following is dimensional and general data for spring pins recognized as American National Standard, which are widely used in general industrial applications per. ANSI/ASME B18.8.2.
All dimensions are in inches.
Where specifying nominal size in decimals, zeros preceding decimal point are omitted.
Length increments are 1⁄16 inch from 1⁄8 to 1 inch; 1⁄8 from 1 inch to 2 inches; and 1⁄4 inch from 2 inches
to 6 inches.
Engineering, design and manufacturing reference data
Nominal Size or Basic |
G | H | C | T | Suggested Hole Size |
Double Shear Lbs. | |||||
Pin Diameter | Chamfer Diameter | Chamfer Length | Wall Thickness |
Max | Min | Max | Max | Min | Basic | Max | Min | SAE 1070- 1095 Steel & 420 SS |
300 Series Stainless |
1/16 | .062 | 0.069 | 0.066 | 0.059 | 0.028 | 0.007 | 0.012 | 0.065 | 0.062 | 430 | 250 |
5/64 | .078 | 0.086 | 0.083 | 0.075 | 0.032 | 0.008 | 0.018 | 0.081 | 0.078 | 800 | 460 |
3/32 | .094 | 0.103 | 0.099 | 0.091 | 0.038 | 0.008 | 0.022 | 0.097 | 0.094 | 1150 | 670 |
1/8 | .125 | 0.135 | 0.131 | 0.122 | 0.044 | 0.008 | 0.028 | 0.129 | 0.125 | 1875 | 1090 |
5/32 | .156 | 0.167 | 0.162 | 0.151 | 0.048 | 0.010 | 0.032 | 0.160 | 0.156 | 2750 | 1600 |
3/16 | .188 | 0.199 | 0.194 | 0.182 | 0.055 | 0.011 | 0.040 | 0.192 | 0.187 | 4150 | 2425 |
7/32 | .219 | 0.232 | 0.226 | 0.214 | 0.065 | 0.011 | 0.048 | 0.224 | 0.219 | 5850 | 3400 |
1/4 | .250 | 0.264 | 0.258 | 0.245 | 0.068 | 0.012 | 0.048 | 0.256 | 0.250 | 7050 | 4100 |
5/16 | .312 | 0.330 | 0.321 | 0.306 | 0.080 | 0.014 | 0.062 | 0.318 | 0.312 | 10800 | 6300 |
3/8 | .375 | 0.395 | 0.385 | 0.368 | 0.095 | 0.016 | 0.077 | 0.382 | 0.375 | 16300 | 9500 |
7/16 | .438 | 0.459 | 0.448 | 0.430 | 0.095 | 0.017 | 0.077 | 0.445 | 0.437 | 19800 | 11500 |
1/2 | .500 | 0.524 | 0.513 | 0.485 | 0.110 | 0.025 | 0.094 | 0.510 | 0.500 | 27100 | 15800 |
