Ultimate Strength, Modulus of Elasticity, Yield Point of Metals Table Chart
Engineering Metals and Materials
Beam Deflection & Structural Analysis
Engineering Analysis
The table given below specifies Ultimate Strength, Modulus of Elasticity, Yield Point, Compression, Shear POint and other properties of selected engineering materials.
Other mechanical properties of metals include ductility , i.e. their capacity for plastic deformation . Reversible elastic deformation in metals can be described by Hooke's Law for restoring forces, where the stress is linearly proportional to the strain . Forces larger than the elastic limit , or heat, may cause a permanent (irreversible) deformation of the object, known as plastic deformation or plasticity .
Material
Ultimate Strength | Yield Point X 1000/in2 |
Modulus of Elasticity | |||
(T) Tension |
Compression, |
Shear in terms of T |
in Tension (E) x 106 psi |
in Shear, |
Cast iron, gray class 20 |
20a |
3.6 T - 4.4 T |
1.6 T |
11.6 | 0.40 E |
class 25 |
25a |
3.6 T - 4.4 T | 1.4 T | ....... |
14.2 | 0.40 E |
class 30 |
30a |
3.6 T - 4.4 T |
1.4 T |
14.5 | 0.40 E |
class 35 |
35a |
16.0 | 0.40 E |
class 40 |
40a |
3.6 T - 4.4 T |
1.3 T |
17 | 0.40 E |
class 50 |
50a |
3.6 T - 4.4 T |
1.3 T |
18 | 0.40 E |
class 60 |
60a |
2.8 T |
1.O T |
19.9 | 0.40 E |
Malleable |
40 to 100 |
30 to 80 |
25 | 0.43 E |
nodular (ductile iron) |
60 to 120 |
40 to 90 |
23 | ...... |
Cast Steel, carbon |
60 to 100 |
T |
0.75 T |
30 to 70 |
30 | 0.38 E |
low alloy |
70 to 200 |
T |
0.75 T |
45 to 170 |
30 | 0.38 E |
Steel, SAE 950 |
66 to 70 |
T |
0.75 T |
45 to 50- |
30 | 0.38 E |
1025 (low carbon) |
60 to 103 |
T |
0.75 T |
40 to 90 |
30 | 0.38 E |
1045 (medium carbon) |
80 to 182 |
T |
0.75 T |
50 to 162 |
30 | 0.38 E |
1095 (high carbon) |
90 to 213 |
T |
0.75 T |
20 to 150 |
30 | 0.38 E |
1112 ( free cutting) |
60 to 100 |
T |
0.75 T |
30 to 95 |
30 | 0.38 E |
1212 ( free cutting) |
57 to 80 |
T |
0.75 T |
25 to 72 |
30 | 0.38 E |
1330 (alloy) |
90 to 162 |
T |
0.75 T |
27 to 149 |
30 | 0.38 E |
2517 (alloy) |
88 to 190 |
T |
0.75 T |
60 to 155 |
30 | 0.38 E |
3140 (alloy) |
93 - 188 |
T |
0.75 T |
62 to 162 |
30 | 0.38 E |
3310 (alloy) |
104 to 172 |
T |
0.75 T |
56 to 142 |
30 | 0.38 E |
4023 (alloy) |
105 to 170 |
T |
0.75 T |
60 to 114 |
30 | 0.38 E |
4130 (alloy) |
81 to 179 |
T |
0.75 T |
46 to 161 |
30 | 0.38 E |
4340 (alloy) |
109 to 220 |
T |
0.75 T |
68 to 200 |
30 | 0.38 E |
4640 (alloy) |
98 to 192 |
T |
0.75 T |
62 to 169 |
30 | 0.38 E |
4820 (alloy) |
98 to 209 |
T |
0.75 T |
68 to 184 |
30 | 0.38 E |
5150 (alloy) |
98 to 210 |
T |
0.75 T |
51 to 190 |
30 | 0.38 E |
52100 (alloy) |
100 to 238 |
T |
0.75 T |
81 to 228 | 30 | 0.38 E |
6150 (alloy) |
96 to 228 |
T |
0.75 T |
59 to 210 |
30 | 0.38 E |
8650 (alloy) | 110 to 228 | T | 0.75 T | 69 to 206 | 30 | 0.38 E |
8740 (alloy) | 100 to 179 | T | 0.75 T | 60 to 165 | 30 | 0.38 E |
9310 (alloy) | 117 to 187 | T | 0.75 T | 63 to 162 | 30 | 0.38 E |
9840 (alloy) | 120 to 285 | T | 0.75 T | 45 to 50 | 30 | 0.38 E |
Steel Stainless, SAE | ||||||
30302f | 85 to 125 | T | ....... | 35 to 95 | 28 | 0.45 E |
30321f | 85 to 95 | T | ....... | 30 to 60 | 28 | ....... |
30347f | 90 to 100 | T | ....... | 35 to 65 | 28 | 0.40 E |
51420f | 95 to 230 | T | ....... | 50 to 195 | 29 | ....... |
51430f | 75 to 85 | T | ....... | 40 to 70 | 29 | ....... |
51446f | 80 to 85 | T | ....... | 50 to 70 | 29 | ....... |
51501f | 70 to 175 | T | ....... | 30 to 135 | 29 | ....... |
Structural Steel | ||||||
Common | 60 to 75 | T | 0.75 T | 33 | 29 | 0.41 E |
Rivet | 52 to 62 | T | 0.75 T | 28 | 29 | ....... |
Rivet, high strength | 68 to 82 | T | 0.75 T | 38 | 29 | ....... |
Wrought iron | 34 to 54 | T | 0.75 T | 23 to 32 | 28 | ....... |
a - Minimum specified value of the American Society of Testing Materials. References Cast iron ASTM A48, structural steel fro bridges and structures, ASTM A7. Structural rivet steel , ASTM A141; high-strength structural rivet steel, ASTM A195
