Engineering Metals and Materials
Thermal Conductivity, Heat Transfer Review
Metals in general have high electrical conductivity, high thermal conductivity, and high density. Typically they are malleable and ductile, deforming under stress without cleaving. In terms of optical properties, metals are shiny and lustrous. Sheets of metal beyond a few micrometres in thickness appear opaque, but gold leaf transmits green light.
Although most metals have higher densities than most nonmetals, there is wide variation in their densities, Lithium being the least dense solid element and osmium the densest. The alkali and alkaline earth metals in groups I A and II A are referred to as the light metals because they have low density, low hardness, and low melting points. The high density of most metals is due to the tightly packed crystal lattice of the metallic structure. The strength of metallic bonds for different metals reaches a maximum around the center of the transition metal series, as those elements have large amounts of delocalized electrons in tight binding type metallic bonds. However, other factors (such as atomic radius, nuclear charge, number of bonds orbitals, overlap of orbital energies and crystal form) are involved as well.
See conversion formulae at bottom:
Material |
Btu / (hr-ft-F) |
Density (lbs/in3) |
Specific Heat
(Btu/lb/F) |
Melting Point (F) |
Latent Heat of Fusion (Btu/lb) |
Thermal Expansion (in/in/F x 10-6) |
Aluminum |
136 |
0.098 |
0.24 |
1220 |
169 |
13.1 |
Antimony |
120 |
Brass (Yellow) |
69.33 |
0.306 |
0.096 |
1724 |
11.2 |
Cadmium |
Copper |
231 |
0.322 |
0.095 |
1976 |
91.1 |
9.8 |
Gold |
183 |
0.698 |
0.032 |
1945 |
29 |
7.9 |
Incoloy 800 |
0.29 |
0.13 |
2500 |
7.9 |
Inconel 600 |
0.304 |
0.126 |
2500 |
5.8 |
Iron, Cast |
46.33 |
0.26 |
0.12 |
2150 |
6 |
Lead, solid |
20.39 |
0.41 |
0.032 |
621 |
11.3 |
16.4 |
Lead, Liquid |
0.387 |
0.037 |
Magnesium |
0.063 |
0.27 |
1202 |
160 |
14 |
Molybdenum |
0.369 |
0.071 |
4750 |
126 |
2.9 |
Monel 400 |
0.319 |
0.11 |
2400 |
6.4 |
Nickel |
52.4 |
0.321 |
0.12 |
2642 |
133 |
5.8 |
Nichrome (80% NI-20% Cr) |
0.302 |
0.11 |
2550 |
7.3 |
Platinum |
41.36 |
0.775 |
0.035 |
3225 |
49 |
4.9 |
Silver |
247.87 |
0.379 |
0.057 |
1760 |
38 |
10.8 |
Solder (50% Pb-50% Sn) |
0.323 |
0.051 |
361 |
17 |
13.1 |
Steel, mild |
26.0 - 37.5 |
0.284 |
0.122 |
2570 |
6.7 |
Steel, Stainless 304 |
8.09 |
0.286 |
0.120 |
2550 |
9.6 |
Steel, Stainless 430 |
8.11 |
0.275 |
0.110 |
2650 |
6 |
Tantalum |
0.6 |
0.035 |
5425 |
3.6 |
Tin, solid |
38.48 |
0.263 |
0.065 |
450 |
26.1 |
13 |
Tin, Liquid |
0.253 |
0.052 |
Titanium 99.0% |
12.65 |
0.164 |
0.13 |
3035 |
4.7 |
Tungsten |
100.53 |
0.697 |
0.04 |
6170 |
79 |
2.5 |
Type metal (85% Pb-15% Sb) |
0.387 |
0.04 |
500 |
14+- |
Zinc |
67.023 |
0.258 |
0.096 |
786 |
43.3 |
22.1 |
Zirconium |
145 |
0.234 |
0.067 |
3350 |
108 |
3.2 |
Metals Thermal Properties |
Material |
Conductivity
W/m-C |
Density
kg/m3 |
Specific Heat
J/kg-°C |
Aluminum, 2024, Temper-T351 |
143.0 |
2.8 x 103 |
795.0 |
Aluminum, 2024, Temper-T4 |
121.0 |
2.8 x 103 |
795.0 |
Aluminum, 5052, Temper-H32 |
138.0 |
2.68 x 103 |
963.0 |
Aluminum, 5052, Temper-O |
144.0 |
2.69 x 103 |
963.0 |
Aluminum, 6061, Temper-O |
180.0 |
2.71 x 103 |
1.256 x 103 |
Aluminum, 6061, Temper-T4 |
154.0 |
2.71 x 103 |
1.256 x 103 |
Aluminum, 6061, Temper-T6 |
167.0 |
2.71 x 103 |
1.256 x 103 |
Aluminum, 7075, Temper-T6 |
130.0 |
2.8 x 103 |
1.047 x 103 |
Aluminum, A356, Temper-T6 |
128.0 |
2.76 x 103 |
900.0 |
Aluminum, Pure |
220.0 |
2.707 x 103 |
896.0 |
Beryllium, Pure |
175.0 |
1.85 x 103 |
1.885 x 103 |
Brass, Red, 85%Cu-15%Zn |
151.0 |
8.8 x 103 |
380.0 |
Brass, Yellow, 65%Cu-35%Zn |
119.0 |
8.8 x 103 |
380.0 |
Copper, Alloy, 11000 |
388.0 |
8.933 x 103 |
385.0 |
Copper, Aluminum bronze, 95%Cu-5%Al |
83.0 |
8.666 x 103 |
410.0 |
Copper, Brass, 70%Cu-30%Zn |
111.0 |
8.522 x 103 |
385.0 |
Copper, Bronze, 75%Cu-25%Sn |
26.0 |
8.666 x 103 |
343.0 |
Copper, Constantan, 60%Cu-40%Ni |
22.7 |
8.922 x 103 |
410.0 |
Copper, Drawn Wire |
287.0 |
8.8 x 103 |
376.0 |
Copper, German silver, 62%Cu-15%Ni-22%Zn |
24.9 |
8.618 x 103 |
394.0 |
Copper, Pure |
386.0 |
8.954 x 103 |
380.0 |
Copper, Red brass, 85%Cu-9%Sn-6%Zn |
61.0 |
8.714 x 103 |
385.0 |
Gold, Pure |
318.0 |
18.9 x 103 |
130.0 |
Invar, 64%Fe-35%Ni |
13.8 |
8.13 x 103 |
480.0 |
Iron, Cast |
55.0 |
7.92 x 103 |
456.0 |
Iron, Pure |
71.8 |
7.897 x 103 |
452.0 |
Iron, Wrought, 0.5%C |
59.0 |
7.849 x 103 |
460.0 |
Kovar, 54%Fe-29%Ni-17%Co |
16.3 |
8.36 x 103 |
432.0 |
Lead, Pure |
35.0 |
11.373 x 103 |
130.0 |
Magnesium, Mg-Al, Electrolytic, 8%Al-2%Zn |
66.0 |
1.81 x 103 |
1.0 x 103 |
Magnesium, Pure |
171.0 |
1.746 x 103 |
1.013 x 103 |
Molybdenum |
130.0 |
10.22 x 103 |
251.0 |
Nichrome, 80%Ni-20%Cr |
12.0 |
8.4 x 103 |
420.0 |
Nickel, Ni-Cr, 80%Ni-20%Cr |
12.6 |
8.314 x 103 |
444.0 |
Nickel, Ni-Cr, 90%Ni-10%Cr |
17.0 |
8.666 x 103 |
444.0 |
Nickel, Pure |
99.0 |
8.906 x 103 |
445.9 |
Silver, Pure |
418.0 |
10.51 x 103 |
230.0 |
Solder, Hard, 80%Au-20%Sn |
57.0 |
15.0 x 103 |
15.0 |
Solder, Hard, 88%Au-12%Ge |
88.0 |
15.0 x 103 |
No Data |
Solder, Hard, 95%Au-3%Si |
94.0 |
15.7 x 103 |
147.0 |
Solder, Soft, 60%Sn-40%Pb |
50.0 |
9.29 x 103 |
180.0 |
Solder, Soft, 63%Sn-37%Pb |
51.0 |
9.25 x 103 |
180.0 |
Solder, Soft, 92.5%Pb-2.5%Ag-5%In |
39.0 |
12.0 x 103 |
No Data |
Solder, Soft, 95%Pb-5%Sn |
32.3 |
11.0 x 103 |
134.0 |
Steel, Carbon, 0.5%C |
54.0 |
7.833 x 103 |
465.0 |
Steel, Carbon, 1.0%C |
43.0 |
7.801 x 103 |
473.0 |
Steel, Carbon, 1.5%C |
36.0 |
7.753 x 103 |
486.0 |
Steel, Chrome, Cr0% |
73.0 |
7.897 x 103 |
452.0 |
Steel, Chrome, Cr1% |
61.0 |
7.865 x 103 |
460.0 |
Steel, Chrome, Cr20% |
22.0 |
7.689 x 103 |
460.0 |
Steel, Chrome, Cr5% |
40.0 |
7.833 x 103 |
460.0 |
Steel, Chrome-Nickel, 18%Cr-8%Ni |
16.3 |
7.817 x 103 |
460.0 |
Steel, Invar, 36%Ni |
10.7 |
8.137 x 103 |
460.0 |
Steel, Nickel, Ni0% |
73.0 |
7.897 x 103 |
452.0 |
Steel, Nickel, Ni20% |
19.0 |
7.933 x 103 |
460.0 |
Steel, Nickel, Ni40% |
10.0 |
8.169 x 103 |
460.0 |
Steel, Nickel, Ni80% |
35.0 |
8.618 x 103 |
460.0 |
Steel, SAE 1010 |
59.0 |
7.832 x 103 |
434.0 |
Steel, SAE 1010, Sheet |
63.9 |
7.832 x 103 |
434.0 |
Steel, Stainless, 316 |
16.26 |
8.0272 x 103 |
502.1 |
Steel, Tungsten, W0% |
73.0 |
7.897 x 103 |
452.0 |
Steel, Tungsten, W1% |
66.0 |
7.913 x 103 |
448.0 |
Steel, Tungsten, W10% |
48.0 |
8.314 x 103 |
419.0 |
Steel, Tungsten, W5% |
54.0 |
8.073 x 103 |
435.0 |
Tin, Cast, Hammered |
62.5 |
7.352 x 103 |
226.0 |
Tin, Pure |
64.0 |
7.304 x 103 |
226.5 |
Titanium |
15.6 |
4.51 x 103 |
544.0 |
Tungsten |
180.0 |
19.35 x 103 |
134.4 |
Zinc, Pure |
112.2 |
7.144 x 103 |
384.3 |
Thermal Conductivity Conversions:
1 cal/cm2/cm/sec/°C = 10.63 watts/in - °C
117 BTU/(hr-ft F) x (.293 watt-hr/BTU) x (1.8F/C) x (ft/12 in.) = 5.14 watts/in - °C
or
117 Btu / (hr-ft-F) x .04395 watt-hr-F-ft/(Btu=°C - in) = 5.14 watts/in-°C
See our Material Manufacturing Definitions & Conversion pages for more information!
© Copyright 2000 -
2024, by Engineers Edge, LLC www.engineersedge.com
All rights reserved Disclaimer |
Feedback Advertising
| Contact
