Shrink Fit of Links or Anchors of Length Equations
Engineering Analysis
Strength and Mechanics of Materials Menu
Shrink-fit connections utilizing a link or anchor are widely used in machine design and construction.
The average compression in the part of rim affected according to C. D. Albert
σc = F / ( Ab Ar )0.5
The tensile stress in link formula
σt = ( Lf - Lo ) / Lo
The total load on link formula
Eq. 3
F = [ ( Lf - Lo ) E A ] / Lo
The compressive stress in rim formula
Eq. 4
σc = [ ( Lf - Lo ) / Lo ] ( E A ) / ( Ab Ar )0.5
The original length of link
Eq. 5
Lo = L / [ 1 + ( 1 + ( E A ) / ( Ab Ar )0.5 ) ( σr / E ) ]
The necessary linear interference δ for shrink anchors
Eq. 6
δ = σd l / L
The force exerted by an anchor
Eq. 7
F = a b σd
Eq. 8
b / a = 2 to 3
Eq. 9
σd design stress based on a reliability factor of 1.25
Figure 1 Shrink links or anchors
where
F = load , kN (lbf)
E = modulus of elasticity or Young’s modulus, Pa [psi (lb/in2)]
A = cross section area, m2, in2
Ab = area bearing surface rim, m2, in2
Ar = area rim, m2, in2
Lo = original length, m (in)
Lf = final length, m (in)
l = effective length of anchor, m (in)
ρ = mass density, kg/m3 (lbm/in3)
v = Poisson's ratio
u = displacement, m (in)
- Preferred Force Shrink Fits Chart ANSI B4.1 Calculator
- Bushing and Plain Bearings Press or Shrink Fit Design and Application
- Shrink Thermal Fit Review
- Interference Pressure Mechanical Tolerances Variability Equations and Calculator
- Cylinder Feature Press Fit Design Equations
Machine Design Handbook 2nd Edition, 2001
Prof. Dr. K. Lingaiah
Former Principal, Professor and Head, Department of Mechanical Engineering
University Visvesvaraya College of Engineering, Bangalore University, Bangalore
