Gauge Blocks Tolerances Specifications Table BS 4311
Accuracy Specifications table for Gage Blocks by BS 4311: Part 1: 1993 (UK) standard at 20˚C.
Nominal length
(mm)
Grade K
Grade 0
Tolerance on
length 1 (µinches)
Parallelism
(µinches)
Flatness
(µinches)
Tolerance on
length1 (µinches)
Parallelism
(µinches)
Flatness
(µinches)
over 0
up to 0.4
±5
2
2
±5
4
4
over 10
up to 25
±6
2
2
±6
4
4
over 25
up to 50
±8
3
2
±8
4
4
over 50
up to 75
±10
3
2
±10
5
4
over 75
up to 100
±12
3
2
±12
5
4
Nominal length
(mm)
Grade 1
Grade 2
Tolerance on
length1 (µinches)
Parallelism
(µinches)
Flatness
(µinches)
Tolerance on
length1 (µinches)
Parallelism
(µinches)
Flatness
(µinches)
over 0
up to 0.4
±10
6
6
±20
12
10
over 10
up to 25
±12
6
6
±25
12
10
over 25
up to 50
±15
7
6
±30
12
10
over 50
up to 75
±20
7
6
±40
14
10
over 75
up to 100
±25
8
6
±50
14
10
SI Units Table
Nominal length (mm)
Grade K
Grade 0
Tolerance on
length1 (0.01µm)
Parallelism
(0.01µm)
Flatness
(0.01µm)
Tolerance on
length1 (0.01µm)
Parallelism
(0.01µm)
Flatness
(0.01µm)
over 0
up to 10
±12
5
5
±12
10
10
over 10
up to 25
±15
5
5
±15
10
10
over 25
up to 50
±20
6
5
±20
10
10
over 50
up to 75
±25
6
5
±25
12
10
over 75
up to 100
±30
7
5
±30
12
10
Nominal length (mm)
Grade 1
Grade 2
Tolerance on
length1 (0.01µm)
Parallelism
(0.01µm)
Flatness
(0.01µm)
Tolerance on
length1 (0.01µm)
Parallelism
(0.01µm)
Flatness
(0.01µm)
over 0
up to 10
±25
16
15
±50
30
25
over 10
up to 25
±30
16
15
±60
30
25
over 25
up to 50
±40
18
15
±80
30
25
over 50
up to 75
±50
18
15
±100
35
25
over 75
up to 100
±60
20
15
±120
35
25
1 At the center point
Related Resources:
