Pressure Vessel Required Shell Thickness Chart
Pressure Vessel Engineering & Design
The following graphical chart is used to determine the minimum pressure vessel shell thickness for material SA-516-70 at temperatures less than 500°F. Allowable stress: 20,000 psi joint efficiency 1.0.
