Linear Stages Review
Industrial Engineering Equipment Knowledge
Linear Stages are precision motion devices that consist of a base that is mounted on linear slides. The base is driven or moved linearly along the slides either by precision manual positioners or electronic/electric controlled positioners. Linear stages are single axis positioning devices. Linear stages may be positioned with an accuracy of 0.025 micro-meters or better and total distance travel of up to one meter or more. Some manufacturers allow for the stacking of their linear stages to create a x-y stage or two axis stage.
Linear stages are selected or specified on the following:
- Travel or distance required in each required axis.
- Manual, electronic or CNC controlled
- Mounting or positioning bed size requirements
- Mass supported requirements.
- Position accuracy
- Dynamic load capacity
- Maximum linear velocity required.
- Positioning resolution
Typical applications for linear stages are semiconductor manufacturing, electronics pwb (pcb) manufacturing, machining and others applications requiring high precision positioning in one axis.
