Cross Flow Fans Review
Cross flow fans, sometimes referred to as tangential fans or squirrel cage fans, are configured specifically to create parallel air movement relative to a cylindrical shaped fan or impeller. These fans are used specifically to create even air flow over a fixed distanced or area. Cross flow fans also provide accessable right-angle airflow and are typically packaged in a rectangular shaped casing allowing for installation in corners or other special fit applications.
Cross Flow Fan |
