Thermal Resistance of Floor Coverings
Heat Transfer Engineering
HVAC Systems Engineering
Civil Engineering
Description | Thermal Resistance rc, ft2 · h · °F / Btu |
Bare concrete, no covering |
0 |
Asphalt tile |
0.05 |
Rubber tile |
0.05 |
Light carpet |
0.60 |
Light carpet with rubber pad | 1.00 |
Light carpet with light pad | 1.40 |
Light carpet with heavy pad | 1.70 |
Heavy carpet | 0.80 |
Heavy carpet with rubber pad | 1.20 |
Heavy carpet with light pad | 1.60 |
Heavy carpet with heavy pad | 1.90 |
3/8 in. hardwood | 0.54 |
5/8 in. wood floor (oak) | 0.57 |
1/2 in. oak parquet and pad | 0.68 |
Linoleum | 0.12 |
Marble floor and mudset | 0.18 |
Rubber pad | 0.62 |
Prime urethane underlayment, 3/8 in. | 1.61 |
48 oz. waffled sponge rubber | 0.78 |
Bonded urethane, 1/2 in. | 2.09 |
Notes
1 Carpet pad thickness should not be more than 1/4 in
2 Total thermal resistance of carpet is more a function of thickness than of fiber type
3 Generally, thermal resistance @-value) is approximately 2 6 times the total carpet
thickness in inches
4 Before carpet is installed, verify that the backing is resistant to long periods of continuous
heat up to 120'F
- Heat Loss From House or Building
- Heat Loss through a Single-Pane Window Equation and Calculator
- Heat Loss through a Double-Pane Window Equation and Calculator A double-pane window is considered. The rate of heat transfer through the window and the inner surface temperature are to be determined.
- Heat Loss through Aluminum Framed Window Equations and Calculator Design equations and calculator example Heat Loss through Aluminum Framed Window.
- Heat Loss Through a Wall Equation and Calculator Determine the steady state heat loss through a single wall.
- Heat Loss Through Enclosure Walls Equations and Calculator Determine required wall thickness of an enclosure for temperature control and insulation requirements. Known Design Data: Size (thickness) of insulated enclosure walls and inside and external surface temperatures
- Overall coefficient of heat transfer U of the wall calculator
- Convection Heat Transfer Convection Heat Transfer calculation example
- Thermal Conduction Through a Uniform Material Calculator
- HVAC Heating, Ventilation and Air Conditioning Load Calculator - Membership required to download
Source
Heat Loss Calculations and Principles, A. Bhatia
ASHRAE HVAC Handbook Systems and Equipment
