Estimating Transistor Heat Transfer Equation and Calculator
Heat Transfer Engineering
Thermodynamics
Engineering Physics
Estimating Junction Heat Transfer and Temperature of a Transistor Equation and Calculator
Preview: Estimating Junction Heat Transfer and Temperature of a Transistor
Q = Heat Dissipation (W)
ΔT = Change in temperature (°C)
R = Junction thermal resisitance (°C/W)
Example:
The temperature of the case of a power transistor that is dissipating 3 W is measured to be 50°C. If the junction-to-case resistance of this transistor is specified by the manufacturer to be 15°C/W, determine the temperature at the junction of the transistor. The case temperature of a power transistor and the junction-tocase resistance are given. The junction temperature is to be determined. Assume Steady operating conditions exist.
Analysis The schematic of the transistor is given above, then the junction temperature becomes:
Therefore, the temperature of the transistor junction will be 95°C when its case is at 50°C.
