Related Resources: fluid flow
Steel Pipe Flow Friction Loss for sizes 10" to 12 " inch diameter
Tables are for steel pipe with a surface roughness of C=100.
See also
- Friction Losses in Steel Pipes size 0.5 to 1.25 inch diameter
- Friction Loss in Steel Pipe 1.5" to 3" inch diameter
- Steel Pipe Flow Loss Friction for sizes 4 " to 8 " inch diameter
To adjust for different surface roughness factors, use the following correction factors:
Value of C |
150 |
140 |
130 |
120 |
110 |
100 |
90 |
80 |
70 |
60 |
0.47 |
0.54 |
0.62 |
0.71 |
0.84 |
1.00 |
1.22 |
1.51 |
1.93 |
2.57 |
Friction Losses in Pipe: Standard Weight Steel 10 " Dia. |
Pipe Size, in. 10 |
Pipe Dia., in. 10.02 Velocity, fps |
Surface Rough C 100 hd. loss, ft/100 ft |
gpm |
800 |
3.25 |
0.66 |
850 |
3.46 |
0.74 |
900 |
3.66 |
0.82 |
950 |
3.87 |
0.91 |
1,000 |
4.07 |
1.00 |
1,050 |
4.27 |
1.09 |
1,100 |
4.48 |
1.19 |
1,150 |
4.68 |
1.29 |
1,200 |
4.88 |
1.40 |
1,250 |
5.09 |
1.51 |
1,300 |
5.29 |
1.62 |
1,350 |
5.49 |
1.74 |
1,400 |
5.70 |
1.86 |
1,450 |
5.90 |
1.98 |
1,500 |
6.10 |
2.11 |
1,550 |
6.31 |
2.24 |
1,600 |
6.51 |
2.38 |
1,650 |
6.71 |
2.52 |
1,700 |
6.92 |
2.66 |
1,750 |
7.12 |
2.81 |
1,800 |
7.32 |
3.0 |
1,850 |
7.53 |
3.1 |
1,900 |
7.73 |
3.3 |
1,950 |
7.93 |
3.4 |
2,000 |
8.14 |
3.6 |
2,050 |
8.34 |
3.8 |
2,100 |
8.54 |
3.9 |
2,150 |
8.75 |
4.1 |
2,200 |
8.95 |
4.3 |
2,250 |
9.15 |
4.5 |
2,300 |
9.36 |
4.7 |
Friction Losses in Pipe: Standard Weight Steel 12 " Dia. |
Pipe Size, in. 12 |
Pipe Dia., in. 11.938 Velocity, fps |
gpm |
1,000 |
2.87 |
0.43 |
1,050 |
3.01 |
0.47 |
1,100 |
3.15 |
0.51 |
1,150 |
3.30 |
0.55 |
1,200 |
3.44 |
0.60 |
1,250 |
3.58 |
0.64 |
1,300 |
3.73 |
0.69 |
1,350 |
3.87 |
0.74 |
1,400 |
4.01 |
0.79 |
1,450 |
4.16 |
0.85 |
1,500 |
4.30 |
0.90 |
1,550 |
4.44 |
0.96 |
1,600 |
4.59 |
1.02 |
1,650 |
4.73 |
1.07 |
1,700 |
4.87 |
1.14 |
1,750 |
5.02 |
1.20 |
1,800 |
5.16 |
1.26 |
1,850 |
5.30 |
1.33 |
1,900 |
5.45 |
1.39 |
1,950 |
5.59 |
1.46 |
2,000 |
5.73 |
1.53 |
2,050 |
5.88 |
1.61 |
2,100 |
6.02 |
1.68 |
2,150 |
6.16 |
1.75 |
2,200 |
6.31 |
1.83 |
2,400 |
6.88 |
2.15 |
2,600 |
7.45 |
2.49 |
2,800 |
8.03 |
2.86 |
3,000 |
8.60 |
3.2 |
3,500 |
10.03 |
4.3 |
4,000 |
11.47 |
5.5 |
- Schedule 40 Pipe Dimensions
- Schedule 80 Pipe Dimensions
- Flow of Water in Pipes Equations and Calculator
- Flow Rate of Steam in Schedule 40 Pipe Tables
- Head Loss at Pipe Entrance Equations and Calculator using the head loss coefficient and head loss of a fluid at a smooth bellmouth pipe entrance.
- Head Loss at Pipe Abrupt Exit Equations and Calculator of a fluid.
- Head loss and head loss coefficient equation and calculator of a fluid in across a screen (circular metal wire mesh) inside a pipe.
- Air Pressure Loss per Foot in Steel Pipe Table Estimated pressure drop at the given CFM of free air flow for steel pipe.
- Flow Losses for Valves and Fittings in Equivalent Feet if Pipe.
- Fluid Energy Loss in Fittings and Valves Formula, Calculator and Tables
Source
