Side Load on Pump or Motor Shaft Equation Calculation
Fluid Flow Table of Contents
Direct drive of the pump is always's preferred. When the pump is not direct-driven, the effects of the shaft side load should be considered. Shaft side load directly affects bearing life. The effect on bearing life is the primary reason to minimize side load.
F = (HP x 63024) / (RPM x R)
F is the side load, in pounds against shaft
R is the pitch radius, in inches, of sheave on pump shaft
HP is the driving power applied
to shaft
