Related Resources: fluid flow
DN Diametre Nominal and NPS Nominal Pipe Size Table
Metric Pipe Sizes Dn "Diametre Nominel" per ISO vs NPS "Nominal Pipe Size" Equivalent for DN 6 to DN 2200, NPS Schedule 5 to 30
Welded and Seamless PIpe
NPS |
DN |
OD |
Wall Thickness Inches |
Sch 5S |
Sch 5 |
Sch 10S |
Sch 10 |
Sch 20 |
Sch 30 |
1/8” |
6 |
0.404 |
0.049 |
0.049 |
0.057 |
1/4” |
8 |
0.540 |
0.065 |
0.065 |
0.073 |
3/8” |
10 |
0.675 |
0.065 |
0.065 |
0.073 |
1/2” |
15 |
0.840 |
0.065 |
0.065 |
0.083 |
0.083 |
0.095 |
3/4” |
20 |
1.050 |
0.065 |
0.065 |
0.083 |
0.083 |
0.095 |
1” |
25 |
1.315 |
0.065 |
0.065 |
0.109 |
0.109 |
0.114 |
1-1/4” |
32 |
1.660 |
0.065 |
0.065 |
0.109 |
0.109 |
0.117 |
1-1/2” |
40 |
1.900 |
0.065 |
0.065 |
0.109 |
0.109 |
0.125 |
2” |
50 |
2.375 |
0.065 |
0.065 |
0.109 |
0.109 |
0.125 |
2-1/2” |
65 |
2.875 |
0.083 |
0.083 |
0.120 |
0.120 |
0.188 |
3” |
80 |
3.500 |
0.083 |
0.083 |
0.120 |
0.120 |
0.188 |
3-1/2” |
90 |
4.000 |
0.083 |
0.083 |
0.120 |
0.120 |
0.188 |
4” |
100 |
4.500 |
0.083 |
0.083 |
0.120 |
0.120 |
0.188 |
4-1/2” |
115 |
5.000 |
5” |
125 |
5.563 |
0.109 |
0.109 |
0.134 |
0.134 |
6” |
150 |
6.625 |
0.109 |
0.109 |
0.134 |
0.134 |
7” |
7.625 |
8” |
200 |
8.625 |
0.109 |
0.109 |
0.148 |
0.148 |
0.250 |
0.277 |
9” |
9.625 |
10” |
250 |
10.75 |
0.134 |
0.134 |
0.165 |
0.165 |
0.250 |
0.307 |
12” |
300 |
12.75 |
0.156 |
0.180 |
0.180 |
0.250 |
0.330 |
14” |
350 |
14.00 |
0.156 |
0.188 |
0.250 |
0.312 |
0.375 |
16” |
400 |
16.00 |
0.165 |
0.188 |
0.250 |
0.312 |
0.375 |
18” |
450 |
18.00 |
0.165 |
0.188 |
0.250 |
0.312 |
0.437 |
20” |
500 |
20.00 |
0.188 |
0.218 |
0.250 |
0.375 |
0.500 |
22” |
550 |
22.00 |
0.188 |
0.218 |
0.250 |
0.375 |
0.500 |
24” |
600 |
24.00 |
0.218 |
0.250 |
0.250 |
0.375 |
0.562 |
26” |
650 |
26.00 |
0.312 |
0.500 |
28” |
700 |
28.00 |
0.312 |
0.500 |
0.625 |
30” |
750 |
30.00 |
0.250 |
0.312 |
0.312 |
0.500 |
0.625 |
32” |
800 |
32.00 |
0.312 |
0.500 |
0.625 |
34” |
850 |
34.00 |
0.312 |
0.500 |
0.625 |
36” |
900 |
36.00 |
0.312 |
0.500 |
40” |
1000 |
40.00 |
42” |
1050 |
42.00 |
44” |
1100 |
44.00 |
46” |
1150 |
46.00 |
48” |
1200 |
48.00 |
52” |
1300 |
52.00 |
56” |
1400 |
56.00 |
60” |
1500 |
60.00 |
64” |
1600 |
64.00 |
68” |
1700 |
68.00 |
72” |
1800 |
72.00 |
76’ |
1900 |
76.00 |
80” |
2000 |
80.00 |
88” |
2200 |
88.00 |
- Schedule 40 Steel Pipe Sizes & Dimensions ANSI American National Standard Schedule 40 Welded and Seamless Steel Pipe.
- Schedule 80 Steel Pipe Sizes & Dimensions ANSI American National Standard Schedule 80 Welded and Seamless Steel Pipe.
- Schedule 40 Plastic PVC, CPVC Pipe Sizes & Dimensions PVC, CPVC and other Schedule 40 Plastic Pipe.
- Schedule 80 Plastic PVC, CPVC Pipe Sizes & Dimensions American National Standard Schedule 80 Welded and Seamless Steel Pipe.
- API Integral-Joint tubing Recommended Torque Table API IJ integral-joint tubing is available in OD sizes of 1.315 to 2.063 in.
- API NUE Tubing Recommended Torque Table Recommended Torque Table for API NUE Tubing.
- API Tubing Engineering Table Chart API Tubing Engineering Table Chart
- API Tubing Grade & Specifications The following guidelines apply to the use of API tubing grades.
- API Casing 4.500 - 5.000 Dia. Engineering Data Table Specification 5C3 of the American Petroleum Institute standardizes 14 casing sizes from 4.5 inches (11.43 cm) to 20 inches (50.80 cm) outside diameter
- API Casing 5.000 - 5.500 Dia. Engineering Data Table API Casing Data Tables sizes 5.00 - 5.50.
- API Casing 5.500 - 6.625 Dia. Engineering Data Table API Casing Data Tables sizes 5.50 - 6.625.
- API Casing 6.625 - 7.000 Dia. Engineering Data Table API Casing Data Tables sizes 6.625 - 7.000 Dia.
- API Casing 7.000 - 7.625 Dia. Engineering Data Table API Casing 7.000 - 7.625 Dia. Table
- API Casing 7.625 Dia. Engineering Data Table API Casing 7.625 Dia. Table
- API Casing 7.625 - 8.625 Dia. Engineering Data Table API Casing 7.625 - 8.625 Dia. Table
- API Casing 9.625 - 10.750 Dia. Engineering Data Table PI Casing 9.625 - 10.750 Dia. Table
- API Casing 10.750 Dia. Engineering Data Table API Casing 10.750 Dia. Table
- API Casing 10.750 - 11.750 Dia. Engineering Data Table PI Casing 10.750 - 11.750 Dia. Table
- API Casing 11.750 - 13.375 Dia. Engineering Data Table API Casing 11.750 - 13.375 Dia. Table
- API Casing 13.500 - 18.375 Dia. Engineering Data Table API Casing 13.500 - 18.375 Dia. Table
