Centrifugal Pump Requirements Spreadsheet Calculator
NOTE:
Fluid Flow Design and Engineering
Requires a Premium Membership to download
Preview: Centrifugal Pump Requirements Spreadsheet Calculator
Download: Centrifugal Pump Requirements Spreadsheet Calculator
How the Worksheet Works
Calculates:
- Friction head loss on suction
- Friction head loss on discharge
- Dynamic head
- NPSH
- System power
- Calculates and creates Pump vs Head Curve
- Considers fittings and valves for both suction and discharge of pump
- Allows for three separate application calculations
Reynolds No. =
Fluid Velocity x Fluid Density x Actual Diameter | |
Fluid Viscosity
If Re > 2100 (Formula taken from Std T2.3 Std 5, Approximate Moody Formula) |
Friction Factor = |
0.0055 x [ 1 + ( 20,000 x Pipe Roughness + 1000000 )]^0.33
[ ( Pipe Diameter Reynolds No. )]
or
If Re < 2100 |
Friction Factor = |
64
Reynolds No.
Pressure Drop = |
5100 x Friction Factor x Velocity^2
Diameter
Type of Pipe
Pipe Roughness (mm)
Drawn Tubing
(Copper, Glass, Stainless Steel, etc.) |
0.0015
Commercial Steel Pipe
0.046
Asphalt Dipped Cast Iron Pipe
0.122
Galvanized Iron Pipe
0.152
Bare Cast Iron Pipe
0.26
Concrete Pipe
0.3 - 3.0
Riveted Steel Pipe
0.9 - 9.0
