UPS Requirements Calculator Spreadsheet
NOTE:
Electronics, Instrumentation & Electrical Database
Uninterrupted Power Supply (UPS) Requirements Calculator Spreadsheet
Download: Uninterrupted Power Supply (UPS) Requirements Calculator Spreadsheet
  • Inverter / UPS Details
    Total Load
    Total Starting Load
    Inverter efficiency
    Size of Inverter / UPS
  • Inverter / UPS Battery Details:
    Battery Voltage Volts DC
    Inverter / UPS Back Up Time Hour
    Loose Connection/Wire Loss Factor:
    Battery Efficiency
    Battery Aging:
    Depth of Discharge:(DOD)
    Battery Operating Temp: C°
    Current drain from battery Amp
    Normal storage capacity of Battery Amp.Hr
    Average Load Amp.Hr
    Size of Battery Amp.hr
  • Battery Bank Connection Detail :
    If You are Select Battery Volt Volts DC
    If You are Select Battery Size Amp.Hr
    Batteries connection for Battery Bank Series-Parallel
    Selection of Batteries Connection:
    Selection of Each Battery Voltage
    Number of String for Battery Bank
    Total Amp.Hr of Each String Amp.Hr
    Total No of Battery in Each String
    Total Battery Bank Amp.Hr Amp.Hr
    Total Nos of Batteries in Battery Bank Nos
  • Results:
    Size of Battery
