NCP3163 Design Calculators Spreadsheet
NOTE:
  • NCP3163 BUCK Topology Calculator Spreadsheet
  • NCP3163 BOOST Topology Calculator Spreadsheet
  • NCP3163 VOLTAGE INVERTING Topology Calculator Spreadsheet
Download: NCP3163 Design Calculators
The NCP3163 Series is a performance enhancement to the popular MC33163 and MC34163 monolithic DC−DC converters. These devices consist of an internal temperature compensated reference, comparator, controlled duty cycle oscillator with an active current limit circuit, driver and high current output switch. This controller was specifically designed to be incorporated in step−down, step−up, or voltage−inverting applications with a minimum number of external components. The NCP3163 comes in an exposed pad package which can greatly increase the power dissipation of the built in power switch.
Features:
  • Output Switch Current in Excess of 3.0 A
  • 3.4 A Peak Switch Current
  • Frequency is Adjustable from 50 kHz to 300 kHz
  • Operation from 2.5 V to 40 V Input
  • Externally Adjustable Operating Frequency
  • Precision 2% Reference for Accurate Output Voltage Control
  • Driver with Bootstrap Capability for Increased Efficiency
  • Cycle−by−Cycle Current Limiting
  • Internal Thermal Shutdown Protection
  • Low Voltage Indicator Output for Direct Microprocessor Interface
  • Exposed Pad Power Package
  • Low Standby Current
  • NCV Prefix for Automotive and Other Applications Requiring Site and Change Control
  • These are Pb−Free Devices
