NCP3063 Design Spreadsheet Calculator Excel
NOTE:
- NCP3063 BUCK Topology Calculator Spreadsheet
- NCP3063 BOOST Topology Calculator Spreadsheet
- NCP3063 VOLTAGE INVERTING Topology Calculator Spreadsheet
Download: NCP3063 Design Calculators
The NCP3063 Series is a higher frequency upgrade to the popular MC34063A and MC33063A monolithic DC−DC converters. These devices consist of an internal temperature compensated reference, comparator, a controlled duty cycle oscillator with an active current limit circuit, a driver and a high current output switch. This series was specifically designed to be incorporated in Step−Down, Step−Up and Voltage−Inverting applications with a minimum number of external components.
Features
- Operation to 40 V Input
- Low Standby Current
- Output Switch Current to 1.5 A
- Output Voltage Adjustable
- Frequency Operation of 150 kHz
- Precision 1.5% Reference
- New Features: Internal Thermal Shutdown with Hysteresis New Features: Cycle−by−Cycle Current Limiting
- Pb−Free Packages are Available Applications
- Step−Down, Step−Up and Inverting supply applications
- High Power LED Lighting • Battery Chargers
