NCP102 Design Spreadsheet Calculator Excel
NOTE:
Download: NCP102 Design Spreadsheet
NCP102 Design Spreadsheet Instructions
This spreadsheet calculates both system and component data for use with the NCP102 in a voltage regulator configuration. Calculations are based on system specifications provided by the user.
This spreadsheet requires macros to be enabled to operate correctly.
