Originally Posted by
jboggs
Once you get into the work force you will find that the real importance of an engineering degree is in the doors it opens for you. You will also find that the more specific the degree is the fewer doors it opens. For example, while a nuclear power plant surely employs several nuclear engineers, I would bet that it employs more individuals with basic mechanical or basic electrical engineering degrees. When those engineers want to move on to other employment, the nuclear engineers have fewer options than the mechanical or the electrical engineers. They almost have to stay within the nuclear industry. The mechanical and electrical engineers do not. I have worked in many environments, and I have worked with several mechanical engineers that used to work in nuclear facilities. But I've never worked in a nuclear plant, so I have never worked with a nuclear engineer.
Another example of this is the aerospace engineer. Airplane manufacturers obviously have a lot of them, but they also have a lot of mechanical and electrical engineers. There are many more examples of this situation.
My point is this: the more generalized your degree is, the more options you will have in the future. A good mechanical engineer that has a good understanding of the mechanical principles of nature can apply that understanding in almost any industry. The same is true for the basic electrical or electronic engineer. But you probably aren't going to find an aerospace engineer designing machinery for a steel mill.
My advice? Stick to the basics. You will find more doors open in your future.
