Thread: Oil pipe design problem
    ganesh1
    Post Oil pipe design problem
    Hello every one ...I am new here on post ...I came across the design problem which include basic mechanics and some finance too...I tried but could not figure out the final answer...I appreciate your help...oil pipe design problem.jpg...
    I attached the the GPEG file...hope u able to open it...
    I found difficulties specially in calculating volume flow rate in that problem...as I tried to get Pimping power ..it gives me direct value...actually all i.e. pressure drop,pumping power and volume must be function of Diameter of pipe...
    Thanks
    Ganesh
    Sure looks like someone is trying the help you by testing your current skill level and knowledge. I give you 9/10 for your skill in asking instead of doing the work to find the answers for yourself.
    If you finally get to the workforce, how will you handle situations such as this? "Boss, just give me a day or two to ask on the Internet how to do this."
    jhon kidman
    hi ganesh that proplem need evaluate the flow the flow rate it so quit easy but first i want the standard dimention of the petrol barrels .....
    175
    The problem is a pure math minimization one
    The initial cost is k1*D +k2/D^4 ; cost of pipe+cost of pumps
    The operating cost is K3/D4 electric power usage
    If you amortize the initial coat over 20 years and add the operating cost you get
    annual cost =k1D/20+k2/D^4/20 +k3/d4
    The curve of cost vs D will show a minimum
    You can find it by setting the 1st derivative to 0 or
    K1/20-4k2/20/D^5-4k3/D^5=0
    and the solution
    1/D=[k1/20/(4k2/20+4k3)]^0.2
    D=[(4k2/20+4k3)/k1/20]^0.2
    You have to find all the K's which should be easy.
