I don't know what size rollers you're talking about but 1/4" tracking error in 3 feet seems pretty severe to me. I recently set up a line running a metal ribbon through a series of 8" dia rollers and process elements at fairly high speed and tension levels over 35 ft end to end. We shot for less than 1/16" error over that whole distance. But the bottom line is the product. If it runs ok, your alignment is good enough. If it doesn't, it isn't. Simple. After repeatedly inserting and removing numerous shims of varying thicknesses over and over again at each roller, I designed roller mounts that provide adjustable alignment in both horizontal and vertical axes. Saved SO much time! Just my thoughts...
