[quote] Now, the problem that I am facing is that the whenever I power on the motor, the entire assembly rotates in the direction that the one way bearing moves. [/qupte]
? Change the voltage polarity on the electrical motor ..
I am developing a motorized cable reel. I am using a geared DC motor to drive central cable drum on which the cable rests. This cable reel is only used to automatically retract the cable back once the cable is pulled out. The cable is pulled out manually by hand from the cable reel.
I am using a one way bearing coupled to my DC motor shaft to make it easy to pull out the cable manually. The one way bearing housing is in turn connected to a small sprocket. The small sprocket is connected to the bigger sprocket (attached to the cable drum) via a chain.
Now, the problem that I am facing is that the whenever I power on the motor, the entire assembly rotates in the direction that the one way bearing moves. But what I need is the assembly needs to rotate in the direction opposite to which the bearing moves. On the side where the bearing rotates freely , I pull the cable out manually (as the bearing makes it easy to pull cable out), and I dont turn on the motor in this case. In the other direction where the bearing doesn't move, I need the entire assembly to rotate in order to pull the cable in, but what happens is that just the motor shaft rotates, the bearing, bearing housing, sprocket, etc dont move.
What modifications should I make to achieve my goal or any other alternatives for this ? I cannot use an electromagnetic clutch here.
Also, below is the link to a video where I explain the problem I am facing. problem explanation video
Also, the one way bearing is connected to the motor shaft via a keyway slot on the bearing and a key on the shaft. I am trying to use the same cycle chain and sprocket concept here and I am trying to understand where I am going wrong here.
Turn the bearing over? I've heard of this referred to as a sprag clutch also.
Timelord
Yes. Try it with the bearing flipped.
