What are the the critical surfaces and the required mechanical tolerances? WIll there be high loads applied?
Investment casting can make this part however it will be expensive and the tolerances will be loose by machining standards. Moreover, the grain structure will be iso-tropic and fatigue loading will be an enemy to this component.
From a cost to manufacture and mechanical tolerances point of view you will need to break this part up.
