Thread: A2-70 Material for Washers
    Jun 2016
    Question A2-70 Material for Washers
    Hello to all,
    If anyone is familiar with this...
    Is it correct for a DIN125A washer to be made from A2-70 material?
    DIN 125, only refers to A2, and not -70 as a codification method.
    Although i have searched the web and found sources that confirm the use of A2-70
    but i have also read that A2-70 should only be mentioned for screws,nuts and bolts.
    Then again i wonder, why not construct washers from A2-70? Is it an abbreviation matter?
    Thank you in advance.
    A washer that conforms to DIN125A can be made from any material of your choosing...
    Jun 2016
    Thanks for the suggestion.
    Jun 2016
    That's what i thought.
    Maybe the problem is in the way you order it...
    For example A2-70 is not correct when referring to washers. !..I don't know..
    Thank you.
