A washer that conforms to DIN125A can be made from any material of your choosing...
Hello to all,
If anyone is familiar with this...
Is it correct for a DIN125A washer to be made from A2-70 material?
DIN 125, only refers to A2, and not -70 as a codification method.
Although i have searched the web and found sources that confirm the use of A2-70
but i have also read that A2-70 should only be mentioned for screws,nuts and bolts.
Then again i wonder, why not construct washers from A2-70? Is it an abbreviation matter?
Thank you in advance.
Thanks for the suggestion.
That's what i thought.
Maybe the problem is in the way you order it...
For example A2-70 is not correct when referring to washers. !..I don't know..
Thank you.
