Results 1 to 1 of 1
Thread: How do I calculate tension force for scattered bolt on plane
    Please find the attached image. I know how to get the shear force for each bolt. But I dont know how to get the tension/compression force of the bolt when it position is not symmetric. I only know the formula to get tension when it is symmetry.
    *I already download excel bolt group analysis from engineering edge, but not sure how of how the formula for tension is obtained). searching for original formula before it got as above formula.
    Edit: Yb in the 2nd pics is actually Zb.
    Last edited by Kelly_Bramble; 12-09-2015 at 08:35 AM. Reason: Remove links and attached images directly
