Thread: How to select best roll forming machine at affordable cost?
    Apr 2015
    4
    Hi Friends, anyone suggest how to select the best roll forming machine for industry use.
    The factors controlling this selection are the maximum thickness and stiffness of the metal sheet to be processed, the desired dialy production throughput and the units aquisition cost restraints.
    The metal thickness and required throughput, ie rolling speed, determine the amount of rolling horsepower required. The throughput and cost restraints determine the sophistication of the machine that can range from a simple hand cranked manually operated unit through a low cost, low production rate motor driven unit, up to an automated motor driven unit with automated feeding and unloading to meet the machines required daily production rate.
    Dec 2015
    My suggection about roll forming machine
    how fast machine should be work.
    production budget and the expected quantity should be kept in mind.
    Get information about machines life.
    Get information about machine market price and machine warranty.
    steel decking floor roll forming machine are generally used for industrial applications.
    Banned
    Jun 2016
    5
    very useful information. Thanks for the suggestion!
