Thread: External Flat Broaching Failure
    Mar 2015
    Scratch occuring during broaching operation on the flat wall... What is the reason of this failure mode
    Could you please help me about this issue?
    Mar 2015
    When we checked the broach tool we only see the damage on chamfer (45 degree). It can be a reason for this failure mode?
    Jul 2015
    5
    It can be a microstructure of material you have to check it.
    Jul 2015
    It's hard to draw a lot off the picture, but the surface looks like its been galled. I would check the relief angle on the rougher and finisher teeth. I would also check the gullet of the broach to insure you have enough space for the chip being pulled by he tooth.
    Other checks to insure you are starting off correctly:
    - Insure the pitch of tooth form allows you to have 2 teeth engaged through out the cut. With out this you can't control material removal rate. This also causes broken teeth and poor finishes.
    - Insure finisher teeth have zero rise after 1st tooth.
    Hope this helps,
    Tom
