Thread: Automating a Fluid Dispenser with an Arduino
    TEDS
    Hello all!!!
    I would like to automate a process which will require applying force to the plunger of a 5ml syringe to dispense fluid at about 10ul per second onto a 25 mm by 75mm surface and I am thinking of using an arduino to control an actuator that will apply this force to the plunger. I am not sure if this is the best way to go or the best way to go about it . Any help would be greatly appreciated!!!
    Newark, NJ
    299
    Why "arduino"? I just googled it and I wonder why you just don't use proven commercially available methods.
