I hate to say it but that is a pretty common structure approach, and the basic calculations are also straightforward.
You need to be more specific with the Load. Is it a point load at the top? Distributed load all down one edge or something else?
What are the legs supporting? A load? Any twisting component?
If this is a safety concern issue, and I mean you no disrespect, but it sounds like you are out of your depth a little. Given that safety seems to be the main concern then you should (must) get a Structural Engineer to do the calculations. Using results from the faceless Internet folk, (myself included) is a nuts idea when thirty people lay dead under a failed structure.
