Results 1 to 7 of 7
Thread: 10x5 Challenge
    Mar 2013
    10x5 Challenge
    Can anyone solve this seemingly easy problem manually? NOT as easy as it appears. Or is it?
    I'm just curious to see if it can be worked manually.
    175
    Pretty simple problem, but we don't do homework here.
    BTW, why would you need 6 place accuracy?
    Mar 2013
    It's part of the challenge and I have the answer (thanks to cheating with a CAD program). We are aiming for a star here.
    Can you at least give a run down of the formulas or techniques used to figure it manually? I've gotten that "it's simple" answer back before but never an explanation or shown-work as to how it is done. Trial and error works as does some CAD programs, but we looking for old-school work-it-out here.
    The first mistake people make is glancing at it quickly and incorrectly seeing X as being the hypotenuse of a simple right triangle with sides of 10 and 5. That is actually not the case.
    Mar 2013
    BTW, this isn't technically "homework" as for a school or anything. This is a little challenge problem that I developed myself. It came about through an accident and I'm just curious to see what's involved with it. I promise you that you can search every textbook and workbook on planet Earth and you will not find that problem.
    h^2 = x^2 + y^2, Pythagorean theorem and trigonometry. Solve for the small triangle first then one of the large triangle
    175
    Ok, you twisted my arm
    TAN@=(5-COS@)/(10-SIN@)
    I trust you can do the res
    175
    Well, did you solve it?
