Thread: Relaxation of Lag Bolt in Wood Connection
    abqvince52
    I am a structural engineer looking at lag bolt connections between a roof top solar panel support system (racking) and typical residential construction (2x joists or trusses). I have been trying to find information on the long term withdrawal capacity of a single lag bolt. I am interested in determining if over the long term the lag bolt might lose some of the clamping force it exerts on metal foot that connects the rack to the roof. Given the various cycles of temperature swings, wind downforce and uplift, and snow loading and unloading does the lag bolt tend to “relax” its grip on the wood grain?
    Welcome,
    In such instances it would be wise to use bolts and nuts with spreader plates top and bottom to distribute the load over a larger area of the wood.
    There may be uploading with wind lift as well as down loading. Depending on load, 3/16" to 1/4" steel plates the width of the wood and maybe 1.5 x width in length should suffice. Use a flat washer and spring washer under the nut.
    Central USA
    128
    Welcome,
    I agree with this and would also add the use of thread locker or nylock type nuts.
    Ron
